Noob questions: component identification
  • zzay
    • Mar 2016
    • 27
    • Raleigh, NC/Augusta, GA
    what is this little thing with a fuse on it? It has two unused terminal screws on the bottom and I want to do away with it and/or move the fuse into my new fuse box.
    bonus: previous owner fixed a broken bolt on the rear master cylinder with a c-clamp
    80 SG, work in progress
    • 8894
    It is for adding 12V accessories to your bike, not needed for normal operation.
    • zzay
      • Mar 2016
      • 27
      excellent, thank you
      • zzay
        • Mar 2016
        • 27
        What's this can?
          • 8894
          Flasher relay for turn signals.
            Very true.....but I'd leave it as is.
              • 5073
              It is a good place for the leads of a battery charger.
              • mack
                • 2411
                • Ontario, Canada
                The sooner
                you replace that fuse box the better. Good time to clean all the connectors that sit behind the box as well. Here is what I did.
                mack
                79 XS 1100 SF Special
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                https://youtu.be/wB5Jfbp6SUc
                https://youtu.be/RaI3WYHSuWA
                Frankford, Ont, Canada
                613-398-6186
                • zzay
                  • Mar 2016
                  • 27
                  replaced the fuse box with a $9 Amazon special. I'll put liquid electrical tape on the solder joints next weekend. Almost done with the electrical...
                  I decided early on that my first priority would be to get it running. Getting it cleaned up and looking nice will come later. Brakes are the next task on the list.
                    Hi Zzay,
                    The picture is posted upside down which will give some of us a head ache Most people use connectors on the wires to the fuse block. But being unconventional is not a problem around here
                      Yeah, ZZay,
                      I offer them WITH the set of connectors for only $10.00 S&H included. But soldering the wires to the block is another way to go.
