Need some hose/line help
    • 2074
    Riding the bike the other day to work/first ride of XS this season,the hose from my Pingel fuel valve that goes to the carb bung came off.I was able to attach it but what size is the bung? Is it metric or standard? I would think its standard hose I had on there as It is loose.What is the inner diameter of the vacuum hose supposed to be? I want it to go on there tight without a clamp to hold it on.
    • 9981
    This is coming from Hong Kong because it was the least expensive and I'm not in a hurry. There are closer sources. Some parts houses stock it.
    http://www.ebay.com/itm/10-Feet-Prem...oAAOSwq19XCQLH
      • 2074
      But is the OEM hose metric or standard?
        • 9981
        Who cares as long as it works. OEM is most likely a metric measurement since that's what is used in Japan.
        1/4" is 6.35 mm.
        Are you talking about fuel line or vacuum line? What I posted is fuel line.
          • 2074
          Actually I care.I care if the hose falls off and suddenly the bike dies at speed during traffic.Can be deadly.That's why I care!
            • 9981
            Care away. Just trying to uncomplicated things.
            Good luck.
              • 2074
              Should never have tried a serious comment on here.I do care If I crash,not only for me but killing someone else as well.The hose came off easily was trying to find an answer not just whatever fits.
                • 8894
                Try 3/16" for the vac hose.
                  • 8894
                  You can use a clamp to make sure it won't fall off but 3/16" should be a nice tight fit.
                    • 2074
                    Thanks Phil!
                      • 9981
                      Is your name Dick?
                        • 2074
                        You trying to be funny?
                          • 9981
                          Nah, you got that covered Peter.
                            • 2074
                            I asked a question you seem to want to turn this into something else.
                              • 9981
                              Just trying to figure out what was wrong with my response other than you seem to have an issue.
                              I was trying to help but if it's unwelcome I'll not respond to your queries again.
                              Sorry to bother you. SINCERELY
                              Good luck...
