Engine detailing questions
  • mack
    • 2411
    • Ontario, Canada
    Funny
    my yougest daughter just corrected me. Dad you don't have ADD, it's called OCD !!!!
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • zzay
      • Mar 2016
      • 27
      • Raleigh, NC/Augusta, GA
      Originally posted by mack
      thanks, saved for a future project. that motor looks immaculate btw, well done!
      Yes. Keep the steel off the aluminum. Have you ever removed a steel bolt from aluminum that has been in place for a long time? The bolt pops loose and comes out rust free and covered in white powder. The aluminum has turned to salts as the aluminum gives up electrons to the steel. That's galvanic corrosion. Without looking at the chart, I believe stainless is an even worse case. If you want shiny aluminum, keep the steel brushes/wool away from it. The green kitchen scrubbies are fine.
      thanks for the info. I was about to chuck some stainless wire wheels in my drill and go to town on it. guess I'll have to regroup. I don't anticipate a finished product anywhere near the level of cleanliness as the photos mack posted, as I will be cleaning the motor in the frame with the covers on... I mainly just want to get the oxidation and fire extinguisher residue off
      80 SG, work in progress
      • 2manybikes
        • 194
        • Meadows of Dan Va.
        Detailing
        Mack, If I ever had an engine that looked that good, I would put it on display in my shop, and just admire it! That is a work of art. If you could cover even the highlights of how you did it, I would really appreciate it. I have an infinite amount of patience when it comes to my bikes. I will have to say, your example really raised the bar!
        Did you use a clear coat of some type? Does anyone know what was used on them originally? Is there possibly a "better" product than what was used 37 years ago? I had hoped to be finished with mine by this fall, and start something else, but my next project is looking like it may be delayed!
        • hella lai
          • Aug 2021
          • 1
          Originally posted by MadHatter4119
          Try this...http://www.amazon.com/GAR343-KLEAN-S.../dp/B004Y1KX9E can find it in different size can...I didn't care for
          the spray can kind...not as strong...Stuff should make easy work of it...
          http://shop.advanceautoparts.com/p/p...322/10035245-P
          Yeah, you are right dear I also try this product and it is very easy to use. I purchase this spray at a reasonable price through Advance Auto Parts Promotional Codes.
            • 7736
            Link seems to go to the correct site. If anyone has ANY problem, let me know.
            • discountscode
              • 1
              • London
              On the engine, dust, oil leaks, old leaves, sand, and other impurities build.
              • Snareguy
                • May 2021
                • 33
                so only elbow grease and green scuff pads...... I see. If i were planning to paint the engine satin black, I understand i would need to create a rough surface, would 100grit do the job? or should i only stick to the green scruff pads? Thanks!
                  • 7736
                  There is a clear coat of high temp paint on parts of the engine. By now, most of it is gone, but there may still be some left on the engine. Wet sand with 250 grit would give you a good surface, and a nice looking finish.
                    • 2078
                    A bit of good info on polishing the Aluminum:
                    Also, I purchased a product called SharkHide protectant that I've yet to use on my polished parts for my bikes, but it worked great on the rear face of my Cadillac wheels after cleaning the corrosion and brake residue off, as a test area.
