Ordered pod filters for my xs11s. having some carb trouble in the mean time and was wondering if while i have the carbs off if i would need to rejet or do anything to the carbs because of the different filters?
Pod Filters
Initially, no. Leave the stock jetting, pilots and main jets then with some riding check the sparkplug burn color before changing anything......patience grasshopper
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top. -
[QUOTE=motoman;483231]Initially, no. Leave the stock jetting, pilots and main jets then with some riding check the sparkplug burn color before changing anything. An initial idle mixture re-setting would be advised......patience grasshopper
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Not sure fellas. I purchased them from Amazon . The bike is at my Dads house in his garage or I'd check and see. They slide over the mouth of the carb and are held on with a hose clamp. They don't seem to be blocking anything but I'm really not sure what you are speaking of so it might be. I'm new to this79 SFComment
If you post Trbig their name, he can tell you if they'll work without blocking air jet area of intake bells on carbs. Otherwise, I'd still mount one, then look inside at rear of carb bell for any of pod filter mount blocking off air jet intakeNot sure fellas. I purchased them from Amazon . The bike is at my Dads house in his garage or I'd check and see. They slide over the mouth of the carb and are held on with a hose clamp. They don't seem to be blocking anything but I'm really not sure what you are speaking of so it might be. I'm new to this
If there is a lip inside the pod filters...chances are that lip will cover the
air jets...that's no good to get it running good...use the search bar and see
if you can find the pictures of the pods that will block off the air jets...You
can try google to locate those pictures...Good Luck79 XS 1100 Special "Basket Case"Comment
Or, just look at the tech tips, Mods, Carbs, and the Pod filter threads, and you'll find this image!
This is after you have pulled out the actual filter from the mounting part.
Check out the thread, will show you how to make some velocity stacks to allow them to work and be able to tune.
T.C.T. C. Gresham
Thanks TC...See that thread if yours are made like these...You can still use
yours with a little mod here and there...look pretty easy...I decided to stay
with the stock air box...Good Luck79 XS 1100 Special "Basket Case"Comment
