Pod Filters
  • drathmann
    • Apr 2016
    • 11
    • Huntsville, AL.
    Pod Filters
    Ordered pod filters for my xs11s. having some carb trouble in the mean time and was wondering if while i have the carbs off if i would need to rejet or do anything to the carbs because of the different filters?
    79 SF
    Initially, no. Leave the stock jetting, pilots and main jets then with some riding check the sparkplug burn color before changing anything......patience grasshopper.
      [QUOTE=motoman;483231]Initially, no. Leave the stock jetting, pilots and main jets then with some riding check the sparkplug burn color before changing anything. An initial idle mixture re-setting would be advised......patience grasshopper.
      • drathmann
        • Apr 2016
        • 11
        • Huntsville, AL.
        Patience
        Thanks Motoman. Just trying to head off any problems ahead of time, i realized i needed carb help shortly after buying the bike and am looking forward to putting it back together and riding
        79 SF
          The all important question.. What KIND of pod filters.
            Very true Tod........if the mount portion of pod filters block off the air jet in rear of carb bells......it'll NEVER run right, if at all. Good call Tod.
            • drathmann
              • Apr 2016
              • 11
              • Huntsville, AL.
              Not sure fellas. I purchased them from Amazon . The bike is at my Dads house in his garage or I'd check and see. They slide over the mouth of the carb and are held on with a hose clamp. They don't seem to be blocking anything but I'm really not sure what you are speaking of so it might be. I'm new to this
              79 SF
                If you post Trbig their name, he can tell you if they'll work without blocking air jet area of intake bells on carbs. Otherwise, I'd still mount one, then look inside at rear of carb bell for any of pod filter mount blocking off air jet intake.
                • MadHatter4119
                  • Nov 2014
                  • 137
                  • Baltimore, MD.
                  If there is a lip inside the pod filters...chances are that lip will cover the
                  air jets...that's no good to get it running good...use the search bar and see
                  if you can find the pictures of the pods that will block off the air jets...You
                  can try google to locate those pictures...Good Luck
                  79 XS 1100 Special "Basket Case"
                    Or, just look at the tech tips, Mods, Carbs, and the Pod filter threads, and you'll find this image!
                    This is after you have pulled out the actual filter from the mounting part.
                    Check out the thread, will show you how to make some velocity stacks to allow them to work and be able to tune.
                    • MadHatter4119
                      • Nov 2014
                      • 137
                      • Baltimore, MD.
                      Thanks TC...See that thread if yours are made like these...You can still use
                      yours with a little mod here and there...look pretty easy...I decided to stay
                      with the stock air box...Good Luck
                        • 6751
                        EMGO filters...no good without modification...K+N filters ...very good...no mods needed...I went with K+N on my XJ1100...ya get what ya pay for...
                        1980 XS650G Special-Two
                        1993 Honda ST1100
                        • drathmann
                          • Apr 2016
                          • 11
                          • Huntsville, AL.
                          I see the issue after viewing the pics,I'll check it out. Thanks for all the help , it's been invaluable. I'd never have thought to check that.
                          79 SF
