TDC adjustment
    • 8796
    Take the shim out, look at the number printed on the bottom, put one in with a number that is less, take your measurement and determine the correct number needed.
    • MPittma100
      • Aug 2011
      • 2359
      Valves
      Originally posted by coolbikr4684
      When replacing the shims and valve adjustment, how do I do it if the shims are tight. All the threads I find mention I measure the space between but my thinnest shim won't even go in.
      As the valve seats wear, the valves go UP in the cylinder head.
      This closes the lash gap. That is why the lash gets smaller. We are programed to think just the opposite.
      A special tool and a selection of shims is needed to perform the valve adjustments. When performing this repair, always turn the engine by hand. Do NOT use the starter to turn engine while adjusting valves.
      Here is a link to the procedure:
      Some enthusiasts say to remove the cams to adjust valves - a totally incorrect procedure.
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
      • coolbikr4684
        • Dec 2015
        • 33
        • Rosamond, CA.
        Can I still drive my xs if the valves are tight? I drive 14 miles to and from work and won't be able to work on the valves into Sunday.
        1979 XS1100SF
        • MadHatter4119
          • Nov 2014
          • 137
          • Baltimore, MD.
          That's a good question...If I remember correctly...I would say you shouldn't drive it...But I never own a inline 4 engine before...Doesn't the engine run hotter if they are tight...I have always been told a little valve chatter noise is far better than them being tight...Your Call
          79 XS 1100 Special "Basket Case"
            • 9980
            Are you measuring them correctly? 180º opposite the highest point on the lobe where it contacts the shim?
            • coolbikr4684
              • Dec 2015
              • 33
              • Rosamond, CA.
              I'm pretty sure I measured correctly. Well than I will keep it parked until Sunday
              1979 XS1100SF
                • 9980
                If they are all that tight you could burn a valve.
                • coolbikr4684
                  • Dec 2015
                  • 33
                  • Rosamond, CA.
                  When measuring for the shims all my valves are tight so ho do I measure for the correct size? I'm guessing I have to remove the shim and than measure with no shim installed and do the math from there. I just want to make sure I'm measuring correctly before I dive into it and start it.
                  1979 XS1100SF
                    • 9980
                      • 3239
                      Back to the fuel filters... If your in tank filter towers are in good condition, the paper filters do nothing. Bikes have been run decades and decades and decades with the filter towers in the tank. If stuff is getting through the tank filters, assuming they are in good condition, you have bigger problems!
                      ZRX1200
                      Seca 750
                        • 9980
                        I run some little lawn mower filters anyway. Peace of mind.
                        • coolbikr4684
                          • Dec 2015
                          • 33
                          • Rosamond, CA.
                          So my shims weren't as tight as I originally thought there was clearance but minimally.
                          E1 .008 Y285
                          E2 .008 Y285
                          E3 .008 Y285
                          E4 .008 Y280
                          I1 .005 Y280
                          I2 .006 Y275
                          I3 .006 Y275
                          I4 .005 Y275
                          If I follow the chart that I have on some of the threads I would need to change to
                          1 E275
                          2 E275
                          3 E275
                          4 E270
                          1 I265
                          2 I265
                          3 I265
                          4 I270
                          Just want to confirm before I go and buy/exchange some
                          1979 XS1100SF
                          • coolbikr4684
                            • Dec 2015
                            • 33
                            • Rosamond, CA.
                            So I messed up the numbers on the previous post. I mixed up mm and inches, good thing I always measure twice and cut once.
                            So my shims weren't as tight as I originally thought there was clearance but minimally. Measurements were done in inches.
                            E1 .008 Y285
                            E2 .008 Y285
                            E3 .008 Y285
                            E4 .008 Y280
                            I1 .005 Y280
                            I2 .006 Y275
                            I3 .006 Y275
                            I4 .005 Y285
                            If I follow the chart that I have seen on some of the threads I would need to change to
                            E1 280
                            E2 280
                            E3 280
                            E4 265
                            I1 275
                            I2 260
                            I3 260
                            I4 280
                            Just want to confirm before I go and buy/exchange them.
                            __________________
                            1979 XS1100SF
                              • 9980
                              each shim size = .002 in.
