R&R battery
    Thanks Rasputin & Brant for the advice. Tie down did not come with the bike and i never gave it too much thought. I guess I will have to fabricate something after i sort the electrics.
      And NOBODY said anything about the hold down and screw?? It is a sheet metal bar from the lower right to the upper left, as you look at the battery. Pull the screw off the top, tilt out, and unhook the bottom off the battery tray. The battery can now be pulled out IF you have both terminals unbolted.
      Take seat off, Then left side cover. Then remove the keeper bar, then you can remove the battery connections, and slide the battery out the left side.
      T.C
      Yep, that's me, Mr. Nobody! Guess you need to slow down a little when reading the replies!
        • 7830
        OOPS....
        Just call me anybody, cause only nobody is perfect..
        • eddielo
          • Mar 2013
          • 35
          • San Jose, CA
          Thanks all! But still can't figure out how to lift seat. I do have that tie down rod. I have removed it and also have disconnect ground. But's that's as far as I've got. It's that darn seat I'm having trouble with.
          Btw, I found the tool kit! It's never been used either. Pretty neat the way it's stored.
          Anyway, back to figuring out how to lift the seat.
          EL
          2006 Yamaha Morphous "The Space Ship"
          2004 Honda Aero VT750 "Black Beauty"
          2003 Yamaha VStar 650 Classic "primero"
          2000 BMW K1200LT Like new as of 5/10/16
          1999 BMW K1200LT "The Silver Bullet"
          1996 Kawasaki KZ1000P "the 5-0"
          1989 BMW K100RS "White Ghost"
          1986 Honda Goldwing Espencade 1200 (work in progress)
          1982 Honda Goldwing Interstate 1100 (same)
          1980 Yamaha XS1100 fast
          1979 Yamaha XS1100 just as fast
          +6 CTs
            • 2101
            Hi Ed, to remove the seat look under each side and find the 14mm nuts that hold the seat on, loosen them til the stud they are screwed onto slides forward in the slots of the seat hold down bracket. The stud and nut will slide out of the U shaped slot of the frame clip and lift the seat from the rear, it will then slide out of the hold down at the front if you pull towards the rear. GL hth
            • Prisoner6
              • Aug 2013
              • 1184
              • Phoenix, AZ
              ... And whatever you do, Eddie -
              Do not attempt to simply remove those nuts by unscrewing them all the way.
              As John (Schming) said, just loosen them enough so they (and the bolts they're attached to) will slide to the front, out of the frame slots.
              Marco
              1979 Honda CBX
              2002 Kawasaki ZRX1200R
              WE MISS YOU, DON
