dropped cylinders 2 & 3...????
  • MadHatter4119
    • Nov 2014
    • 137
    • Baltimore, MD.
    #76
    Oh those...Don't the plug into the front of the air filter...That's where I got
    them going to...the crank case vent is in between the carb vents on the air
    filter housing...???????
    79 XS 1100 Special "Basket Case"
      Originally posted by BA80
      Why only the right side then Brant? 3 & 4 have nothing in common except fuel delivery.
      A secondary electrical issue IS the common demoninator, even though 3 &4 are not associated directly, plug ignition wise. Fairly sure your following my direction headed.
        • 9980
        That makes NO sense Brant. 3 & 4 are on different coils, different secondary ignition systems.
        • MadHatter4119
          • Nov 2014
          • 137
          • Baltimore, MD.
          #79
          If it's electrical what do I check...I lost spark to 2&3 replaced TCI...The pipes are getting hot now...but running bad...popping , black smoke and
          flame shooting out the right muffler , won't idle...???? Thanks
            Sorry, but makes perfect sense. Secndary ignition ELECTRICAL is the starting point for process of elimination BEFORE attacking the carbs.
              • 9980
              Sounds to me like raw gas getting into the muffler. Pull the plugs out of 3 and 4. See if 1 or both are wet.
                • 9980
                Everything is electrical with you Brant, even my restricted mufflers.
                • MadHatter4119
                  • Nov 2014
                  • 137
                  • Baltimore, MD.
                  #83
                  Will do tomorrow...I'm not smelling any fuel...
                    Your gonna have to quit guessing and use your multi-meter and check that output voltages are same and equal to battery output voltage.......preferably 12v minimum. Key on.....check battery voltage first. Then, key on......voltage TO both coils. That would be a good start, and report back the findings. If voltage TO coils is less than battery voltage, removing, disassembling and cleaning of kill switch contacts WOULD be your next step. If no improvement voltage wise after that, internal cleaning of ignition switch contacts would be next.
                      • 5057
                      #85
                      What does that mean?
                        • 5057
                        #86
                        That is a good call I would say...
                        • MadHatter4119
                          • Nov 2014
                          • 137
                          • Baltimore, MD.
                          #87
                          So Greg...what do I do if the plugs are wet...you thinking floats or what...this was real sudden...it ran good yesterday when I started it
                          ...today I put longer gas lines on...right petcock feeding carbs 1&2
                          and left petcock feeding 3&4...changed it from left petcock feeding 1
                          and 2...right petcock feeding 3&4...Every time i tried to move the gas
                          tank...the lines prevented me from moving the tank any...with them
                          this way...I have some play and can raise the tank a little...
                            • 9980
                            Do you have the airbox on it? AND, is the octy still on it?
                              • 9980
                              Yes, that's where they go but if they are plugged ANYWHERE the carbs will flood.
                              • MadHatter4119
                                • Nov 2014
                                • 137
                                • Baltimore, MD.
                                #90
                                I'll pull those vent lines tomorrow and stick a piece of metal clothes hanger to see if they are open...From what I remember...on the air box...those vent line holes are rather small...if they are blocked...it would have to be at the air box...
