Running rich, I think
  • coolbikr4684
    • Dec 2015
    • 33
    • Rosamond, CA.
    So I have gone through the electrical to confirm I have all good connections and good battery. Coils are in spec verified by 2 meters. Carbs have been torn down and cleaned throughly 3 times. Float adjusted to correct hight and verified by placing a clear tube from drain. Synced using home made tool with four bottles. Now the problem, spark plugs gapped at .030 and all 4 are sooty right before I checked gap and all plugs except #3 were slightly more than .030 and appeared hot the tips were starting to whiten so I re adjust all to .030 and now all sooty. Any thoughts? I'm all out of them.
    1979 XS1100SF
  • mlew
    • Jun 2005
    • 226
    • Apex , NC
    Did you replace the jets? They actually do wear out over time. They are key to proper fuel mixture.
    I have had many problems with aftermarket jets not being the size indicated on the jet. Only buy genuine Mikuni jets they are always right. A complete set of Mikuni jets (mains and pilot)on Amazon.com usually around 30$.
    Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
    Current rides:
    80 XS1100SG
    82 JX1100
    83 Venture Royale
    86 V-Max
    • coolbikr4684
      • Dec 2015
      • 33
      • Rosamond, CA.
      Yea I did, I actually forgot to mention that the mixture screws I needed to replace 2 of them PO had at some point wedged the tips in and broke off.
      1979 XS1100SF
      • mlew
        • Jun 2005
        • 226
        • Apex , NC
        Hopefully you got the old tips out.
        Look through this, the great pilot jet controverst. I think you might be having this problem.
        Current rides:
        80 XS1100SG
        82 JX1100
        83 Venture Royale
        86 V-Max
        • coolbikr4684
          • Dec 2015
          • 33
          • Rosamond, CA.
          http://www.xs11.com/forum/showthread...identification
          I have all the old parts i swapped out for new ones when i did the rebuild (never hurts to have old/used spare parts) and from what i gathered from the posts in that conversation i have the correct ones, i compared all my new parts with the old when i pulled them. would opening the sparks up a little more be the answer? What about my mixture screw does that control the mixture through full throttle?
          1979 XS1100SF
          • mlew
            • Jun 2005
            • 226
            • Apex , NC
            As long as the plug gap is between the recommended .028 to .032. Changing it out of that range will not help.
            The mixture screw only has an effect from idle to around 1//4 throttle.
            I had a similar problem on my sx11SG and found I had the wrong pilot jets. Here is a link that shows the two available. http://www.mikesxs.net/products-39.html#products
            Take a close look at them.
            Carb slide diaphrams and needle position is something else possible. Check to see if they move free and don't have any pinholes in them.
            Current rides:
            80 XS1100SG
            82 JX1100
            83 Venture Royale
            86 V-Max
              • 2053
              Me too
              I had the problem with the K&L jet = wrong size.
              Ran super rich.
              After goosing it, idle stayed high @3k and would not go back down. Turn down the idle speed screw to compensate, and it dies.
              • coolbikr4684
                • Dec 2015
                • 33
                • Rosamond, CA.
                So I finally had time to teardown the carbs. I got some real mikuni jets and replaced the ones that name in my k&l kit and when compared side by side there were differences very slight (almost unnoticeable) ones but still different. I got it to accelerate into 70 - 75, maybe faster Speedo is slightly off. But now new problem my headlight indicator flickers and sometimes stays on. Headlight operates like it's suppose too but indicator light still comes on.
                1979 XS1100SF
                • mlew
                  • Jun 2005
                  • 226
                  • Apex , NC
                  Do some searches on the site for "RLU" the reverse lighting unit is under the seat above the battery. That is the source of the problem.
                  Current rides:
                  80 XS1100SG
                  82 JX1100
                  83 Venture Royale
                  86 V-Max
