Stock Glass Fuse Panel For 79XS11Special
    • 9980
    Looking in the Clymers manual right now, I got curious.
    It only shows 4 fuses. The main, headlight, turn signal, ignition. It seems the tail lights run on the headlight fuse on the SF. Looks like to me anyway.
    • MadHatter4119
      • Nov 2014
      • 137
      • Baltimore, MD.
      I'm getting ready to head out soon...I'll do a quick peek to see if it has a
      30a in it...?
      79 XS 1100 Special "Basket Case"
      • MadHatter4119
        • Nov 2014
        • 137
        • Baltimore, MD.
        Ok...I look at my fuse panel and like I said...It only has three fuses in it...And like you said...The other fuse that should be there must of broke
        ...I found a single inline fuse hidden almost behind the fuse panel...So it
        has a total of 4 fuses...one of them is the main 30a fuse...The other glass
        fuses will be removed soon and that stock panel will be where it belongs...
        in the trash...Later
        • coolbikr4684
          • Dec 2015
          • 33
          • Rosamond, CA.
          Originally posted by MadHatter4119
          Good...Did you just get your...How much was it...I'm on a tight budget
          It was 9$ for the fuse block and 1$ for connectors. Info here ---> http://www.xs11.com/forum/showpost.p...5&postcount=10
          1979 XS1100SF
