Valve Shim Size
  • Azoroth
    • May 2011
    • 82
    • Idaho Falls, ID
    Valve Shim Size
    Hey all, I have a question that I want to ask. I just need to clarify what size the valve shims are. From what I have found, it looks like they are 29mm in diameter. I just want to verify this.
    Also, my sister has a 1982 xj750 Seca. We were planning on doing the shims together so we can switch between the two bikes if needed. Are the shims in her bike the same size? I cant seem to find a definative answer to make sure before we tackle the project(s).
    We want to do this before our annual week long bike ride and just wanna make sure that we don't have to worry about two different sizes.
    Thanks guys
    1980 Yamaha XS1100SG
    1984 Honda VF700F Interceptor
    1967 Yamaha YL2C
    They are definitely 29mm shims. Not sure what the 750 takes though. I do know the KZ1100 uses the same shims, so when I go looking for them on ebay, I usually search for that instead of the XS/XJ. I do have a few shims if you need them (and you're not too far from me), but I'd have to know what size you needed.
    • Geezer
      • May 2003
      • 2985
      • Willamina, Oregon 97229
      All the XSs used 29mm shim. As did many KZ series Kawies as well as the Yamaha built SHO Ford engines but these shims are no longer cheap and easy to come by...
      Geezer
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        Hey, Azoroth -
        Just to clarify ...
        The XJ750 Seca does indeed use 29mm valve shims, the same shims as the XS1100 ...
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
          • 2104
          Originally posted by Prisoner6
          Hey, Azoroth -
          Just to clarify ...
          ^^X2 ^^
          XSactly what I did with my XJ 750 when I adjusted the valves on my '80G was swap in between the two.
          • Abnorml
            • 18
            • Post Falls, ID.
            I also have some extra shims I'd be glad to pass on if you need them. Also, z1 enterprises has 29mm shims for 4.95 ea. I just got 6 from them a week ago.
            80 XS1100SG (the Lazarus Effect)
            81 XJ550 bobber (sold)
            81 XS850 (sold)
              Yeppers.....as C. Bug has stated, the Kaways use same size shims.
              • Azoroth
                • May 2011
                • 82
                • Idaho Falls, ID
                Thanks!!
                Hey thanks everyone for the replies. My dad got the shim removal tool. This should work on both of the bikes right? I know that there are many discussions about pulling the cam's vs using the tool. But we are thinking that the tool is out best option.
                1967 Yamaha YL2C
                  • 2104
                  Yes, the Motion Pro tool will work on both the XJ 750 & XS 1100 engines.
                  Patience is a virtue when adjusting the valves
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    Try here for low priced new shims
                    Valve Shims for Bikes in CRC2's Online Catalog of New motorcycle Parts and Accessories Indy
                    Mike Giroir
                    79 XS-1100 Special
                      If you buy the shims from a local dealer, (Any bike shop that has been open quite a few years should have them) be careful. There is a 29.5mm shim that you can't tell the difference between even holding one of each together. The 29.5 just won't quite fit in the shim bucket. Take a pair of calipers with you or have the shop check them before buying and taking them home.
