Loud Horns
  • HalfCentury
    • 408
    • Burlington NC
    Loud Horns
    I finished wire extensions and looming of the flashers and the horns. The horns are freakishly loud. Sounds like a train or an 18 wheeler.
    The left horn wires were long enough. The right horn required extensions. I cut off the old fastons which are corroded. I cut back the old wire enough to expose clean copper. I own a pair of professional crimpers so the crimps are solid.
    The final touch will be a few black zip ties to keep the loom in place.
    82 XJ1100 - sold
    2000 ZRX1100 - sold
    2003 FJR1300 - Silver rocket
    Which horns are those? I have Fiamm horns on mine, but they look very different. Did yours require a separate relay for power like the Fiamms do?
    • HalfCentury
      • 408
      • Burlington NC
      It is these
      http://www.ebay.com/itm/Red-Super-Lo...VWxRkH&vxp=mtr
      It comes with a relay. I did not install the relay. They seem to work without running fat wires from the battery.
      82 XJ1100 - sold
      2000 ZRX1100 - sold
        Be VERY careful with that! They may look like they work now, but those things draw a LOT of current. The OEM wiring is not meant to carry that kind of load. If you're lucky, you'll end up with a blown fuse. If not, shorted wires and sparks under the fuel tank.
          I totally agree. Use the relay provided and be sure to have a fuse either on the fuse block or inline. Both are cheap insurance of a horn that works without a melt down of the bike.
            Something will fail. Likely the switch. Use the relay.
            • HalfCentury
              • 408
              • Burlington NC
              As per advice given here, I am routing the wires to add the relay. The new relay will go near the fuse panel.
              I will install TopCat's fuse panel and use an extra circuit for the horns.
              I measured the current draw of the horns. I used a precision 75A, 1 milliohm shunt and a 6 1/2 digit DMM.
              The current draw is 7.7 amps with both horns in parallel. An aux battery was used to supply the juice.
              A 15A fuse should be good for the horn circuit. I might get away with a 10A. We shall see.
              The horns are ear splittingly loud.
              Thanks for the advice and for the tips.
              82 XJ1100 - sold
              2000 ZRX1100 - sold
                • 4015
                Phew! Glad somebody was here to prevent that potential problem.
                • MPittma100
                  • Aug 2011
                  • 2359
                  Amen!
                  I could already smell the fire. Was going to strongly suggest buying a fire extinguisher if not using the relay.
                  1981 XS1100H Venturer
                  K&N Air Filter
                  ACCT
                  Custom Paint by Deitz
                  Geezer Rectifier/Regulator
                  Stebel Nautilus Horn
                  EBC Front Rotors
                  Limie Accent Moves On In 2015
                  Mike
