My fork barfed!
Hi Marshall,
Even if you can clear that seal to make it stop leaking. The easiest way to make sure the two sides have equal oil is to drain and refill.
Remove the caps to relieve the pressure before opening the little screw in the drain hole. Otherwise the oil comes shooting out about 4 feet
Ask jetmechmarty for the picture / instructions of how to make the handy tool for getting the cap back on.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
Yep, Newgate mall is about 10 minutes from me. They always install my tires. Not a place for parts, but they might have the seal mate tool. I'll swing by there tomorrow. If not, there's a place called Carey's Cycles not far from there too.1980 XS850SG - Sold
-H. FordComment
Yeppers, that be the one. Not living up there, just have bought a couple helmets from them some 9-10 yrs. ago when visiting siter and bro-inlaw in Layton,.......had forgotten the name of the place.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Well, went to Newgate Honda last night, and got gouged out of $26 for a "variation" of the seal mate called a "Seal Doctor". This one's a harder plastic tool, pre-formed to snap around the fork tube. It comes with a holder that protects it in your tool box. Better design, I suppose, but since I only expect to need this thing once, it was a bit more than I originally wanted to spend.
After using the Seal Doctor, I spent the evening changing the oil on both forks, and managed to mangle the cap on one of them with an end wrench as it slipped off. Smashed the air fitting in the process. I was able to convince it to take air again though. I rode to work today, and will keep an eye on the forks for potential oil leaks. My new seals are expected to ship Friday, so if needed, I can do the whole process next weekend.1980 XS850SG - Sold
-H. FordComment
Super easy. It also has grippy bumps on the sides to help push it around. I can't imagine 35mm film being robust enough to actually push around the seal! Though maybe the fact that it's so thin creates less resistance.1980 XS850SG - Sold
-H. FordComment
And it will hit you in the forhead with stinky fluid!Hi Marshall,
PhilSkids (Sid Hansen)
