What year?
  • timktm
    • Dec 2015
    • 169
    • Ohio
    What year?
    Can you help identify the year of this bike? Ran across it on CL.
    Tim
    1979 xs1100sf black.
    1973 Harley fx.
    2005 Honda 450x.
  • rdmcguy
    • Jul 2013
    • 515
    • Denver, Colo.
    What year ?
    I'm no expert but to my eye it appears to be an 81+
    The black circle on the case along with the YICS in red below and with the swirly mags suggest that to me !
      It is an 82 XJ1100.
        it is an 82 xj1100.
        +1.................
        • timktm
          • Dec 2015
          • 169
          • Ohio
          It is an 82 XJ1100.
          Thanks,
          The guy selling it said it was an 86. I didn't think so. Any parts compatibly with my 79 sf? Or anyone have interest in it near Cleveland? Just like it is in pic, no seat or side covers.
          Tim
          1973 Harley fx.
          2005 Honda 450x.
          • Jerry
            XS & TRUE XJ GURU
            • 3023
            • Elma, IA.
            The XJ (rear disc brake is another indicator) was sold in the US only in '82 and in other markets (Canada and Mexico) through '84.
            Some parts are compatible, same basic transmission and drive line, but the XJ is a different animal than the earlier 1100s and there are changes to carbs, heads, exhaust, tubeless 16" rear tire where your '79 has ( I think) 17" rear tire, wiring, charging, and a bunch of other stuff. Brake rotors are interchangeable. XJ seat does not fit any other 1100 so is sometimes hard to find, same with side covers. What is the guy asking for it?
            Jerry Fields
            '82 XJ 'Sojourn'
            '06 Concours
            My Galleries Page.
            My Blog Page.
            • timktm
              • Dec 2015
              • 169
              • Ohio
              So, the trany is the same in case I have issues with mine? I can get it cheap, like $50. Kind of hard to pass up.
              Tim
              1973 Harley fx.
              2005 Honda 450x.
                Many parts including the engine can be used on the XS, for $50, I wouldn't hesitate.
                • Jerry
                  XS & TRUE XJ GURU
                  • 3023
                  • Elma, IA.
                  Yep, gears, shafts, forks, all the same. Same "2nd gear" shifting issues as well. For that price ($50.00) I would get it, you could sell other parts off of it and make your money back plus more.
                  I just hate to see a pretty complete bike scrapped for parts, but that is another subject entirely!
                  Jerry Fields
                  '82 XJ 'Sojourn'
                  '06 Concours
                  My Galleries Page.
                  My Blog Page.
                    One thing that folks haven't commented on is the XJ's front forks/sliders.
                    Your Special has the wonky swivel calipers, and so it's near impossible to upgrade to newer dual piston calipers and such unless you have a mini-machine shop. See this thread if you're curious what it takes on a special.
                    http://www.xs11.com/forum/showthread.php?t=36309&highlight=special+fork+brak e
                    The XJ's sliders have better fittings like the Standards which are easier to MOD to modern calipers! But I can't remember if the XJ's tubes are wider/thicker than the XS. IF they aren't you could swap out the forks into your TT's. IF they are larger, then you would need to swap the whole front end. JAT!.
                      The XJ forks are different as the air adjustment. The triple tree is part of the air system. The tubes have an air hole and there are rubber o-ring seals in there.
                      Not sure if the lowers could be swapped out or not.
                      • timktm
                        • Dec 2015
                        • 169
                        • Ohio
                        It is rougher that in the picture. Lots of rust. I think more than I'm willing to put into it. Probably just part it out. Whats with the rear brake on this thing. Back brake runs the front partially?
                        1973 Harley fx.
                        2005 Honda 450x.
                        • Prisoner6
                          • Aug 2013
                          • 1184
                          • Phoenix, AZ
                          ... Whats with the rear brake on this thing. Back brake runs the front partially?
                          Yes ...
                          The '82 XJ11 has a linked braking system. Pushing the rear brake pedal activates both the rear caliper and the front left caliper.
                          Marco
                          1979 Honda CBX
                          2002 Kawasaki ZRX1200R
                          WE MISS YOU, DON
                            You can swap the lowers to get the 'better' XJ front brakes as long as you use the special innards (dampers, fork tubes, etc).
                            Other than the missing seat/sidecovers, that's a remarkably complete XJ and in better shape than many start with. I'd be really hesitant to part that one out....
                            • timktm
                              • Dec 2015
                              • 169
                              • Ohio
                              You are correct about it being complete. It will need a frame off restoration. Major rust. I would have way more into it than it is worth.
                              1973 Harley fx.
                              2005 Honda 450x.
