I'm sure we would need to thread in an adapter to account for the height or perhaps they make a different one which could be threaded straight in. Either way, I be getting these on my cages.
Anyone tried these?
Anyone tried these?
I'm sure we would need to thread in an adapter to account for the height or perhaps they make a different one which could be threaded straight in. Either way, I be getting these on my cages.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
I was intrigued by it, until I thought of the knocking my engine made when that valves faips. I like it, but I need more piece of mind.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights. -
+1!..............they are just an overpriced pivoting ball valve. You couldn't even run fast enough to give me one
............but, as they say, 'to each his own
. ' that hot oil will eventually weep past that ball pivot
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Hi Mack,https://www.fumotooildrainvalve.com/
Like you say not sure you can just thread it in to the XS drain hole hidden up in the 1/2 tunnel. They have certainly solved the usual problem by having the correct male thread. Even in a car application I would be concerned about accidental opening. ie rock flies up and hits the handle at just the correct angle to open the valve. it is only a 1/4 turn to full open after all.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
Hey Mack,
Looked at their site a little closer. Also verified our plug size, 14mm x 1.5 pitch.
Here's the one they have in that size! it's their Model F106. This one doesn't have a fitting for a hose,and so the oil would be pouring out against the filter cup....unless you took it off first...which wouldn't matter since the oil stays in the cup no matter if you drain the oil pan first or not...so you still get to experience the mess of dripping oil from the cup!?
These non-nipple valves can simply allow you to drain the oil. No hoses can be used, but their sizes are at minimum, and, compared to the regular drain plugs, they would only be added half inches in length from your oil pans.
This one has a short nippled to attach a drain hose:
These valves have 5 mm (0.2") short hose nipples and are recommended for vehicles with low ground clearance. Our plastic sockets (SH-10 or SL-10) are necessary to securely connect a hose to the nipple.
From the description, the lever is held in a locking recess so it can't easily get knocked OPEN, you have to pull/lift the lever up out of the recess before you can turn it open. But they also offer an optional LOCKING CLIP to position onto/above the lever to further keep it from being accidentally unlocked!
I like the idea. Another option would be to tap and thread it into the SIDE of the oil pan away from the filter cup.
Brant, they've been made since 1976, and here's a blurb from the website about whose installed them commercially!
T.C.Trusted by Major Vehicle Makers and Industries
In Japan, the Fumoto Engine Oil Drain Valve has achieved "Genuine Parts" status by 6 major motor vehicle manufacturers: Toyota, Nissan, Mazda, Mitsubishi, Subaru and Isuzu.
In the United States, the Fumoto Valve has been installed at factory level on some vehicles and equipment made by Ford, Kohler, Freightliner, Caterpillar, JLG, GEHL, Ingersoll-Rand, Sullair, Toyota, Case, Magnetek, Timberjack, Lincoln Electric, Vermeer, Baldor, Terex, Deutz, Phaser Marine Generator.T. C. Gresham
I installed one on a boat engine I use to have. It sure made oil changing much easier and cleaner. I had the one with the nipple and would attach a hose and run it through the bilge drain to a pan. No more spilled oil in the boat. Can't say if it will work that well on a XS.Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
Current rides:
80 XS1100SG
82 JX1100
83 Venture Royale
86 V-MaxComment
Thaks T.C............have been aware of them since then, but just never have had nerve enough to try themHey Mack,
Cages
One of my cages is a dodge 4x4. I'm going to put one on it. Lots of room to work under it but I've always hated the sleeve full of oil thing.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
Ssssssssssssssssssssssslllllllllllllllllllllllllll lllllllllooooooooooooooooooooooowwwwwwwwwwwwwwwwww wwwwww............
Hey Schming,
They offer a 1" long adapter/extension for pans with recessed plugs!
Only $6.50 extra.
I meant to post an image of the valve with the drain nipple.
Hey Greg, we know you're a little "slow", but we'll wait for you!
With the valve, you can get the oil warmed up before draining to help it flow faster without having to get the hot oil on you.T. C. Gresham
Yes Way, there ya go !!!
Whaaat. . .who doesn't warm their "Earl" before drainage ?Hey Schming,
Only $6.50 extra.
With the valve, you can get the oil warmed up before draining to help it flow faster without having to get the hot oil on you.1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
After reading
The information on their web site I ordered one for my Toyota.
No fuss, no muss and changes should take less time now because there's no pre and post cleanup prep required and I can drain the oil straight into gallon milk jugs instead of the oil pan.
I liked the idea immediately when I saw it because I'm all about lazy which means doing it the smart easy way.79 SF & 80 LG MNS
73 & 74 RD 350's
73 Honda CL 450
Graveyard - '81 XS850 Special
All of my bikes are projects, maybe one day I'll have them running.Comment
I wonder
if with the extension it would clear the recess but bind on the cup.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
. Least I gotta be droppin' the oil out of my Ford 7.3L diesel(14qts and a five gallon bucket)
