Hey all I put my bike away to do some exhaust work and decided to try and replace my headlight. So I got this cool HD light from the Internet the kind that has turn signals built into it and I hooked up to my bike and I started it and I made a the light made a funny humming sound and then the bike wouldn't run anymore I have to really Gousset to get it to go. So I figured I didn't like that. And went back to the original headlight configuration. And then I went to start my motorcycle again and it seems to me that the left side doesn't have nearly as much compression as the right side and the left side of the motor is running cooler than the right what could that problem be?
Left side cool right side not
Hey all I put my bike away to do some exhaust work and decided to try and replace my headlight. So I got this cool HD light from the Internet the kind that has turn signals built into it and I hooked up to my bike and I started it and I made a the light made a funny humming sound and then the bike wouldn't run anymore I have to really Gousset to get it to go. So I figured I didn't like that. And went back to the original headlight configuration. And then I went to start my motorcycle again and it seems to me that the left side doesn't have nearly as much compression as the right side and the left side of the motor is running cooler than the right what could that problem be?. You've been a member here long enough, so no testing included is a cop-out
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top. -
The only things I have not checked are the fuses and coils. Plugs wires fuel all good she has never run like this before. I think I will pull the coils and take them to my local shop to check. Otherwise I am really stumped.Ego Sum Meus Frater Custodis...Comment
Coils will affect #1 and #4 cylinders or #2 and #3 in pairs. Usually 1 & 2 or 3 & 4 pairing is a fuel issue. Since you've already eliminated fuel, I think the first thing I'd check is the sync. If you've got inline fuel filters you might check them for obstructions too. Might want to check the vacuum advance line too and make sure it's still in place on both ends.I think I have a loose screw behind the handlebars.
Coils run 1 & 4 and 2 & 3. One fires both outers, the other both inners. Not side to sideGreg
The list changes.Comment
Thanks all I will check all of that have many things I want to replace inclusive the coils. New fuel line etc.also think I will dump and redo the tank. Anyone on here rebuild carbs?ill keep you keep you postedEgo Sum Meus Frater Custodis...Comment
You can R/R the carbs. We'll give you any help needed from here. Remember, the only dumb question is the one never asked, If ya got the stock airbox, remove totally the four long bolts on bottomside of lower portion of airbox. Remove lower portion of airbox and filter out left side, Unbolt airbox bolts on both sides, Completely unscew airbox clamp screws and slide them rearward out of your way. Remove upper airbox and drop it down PAST the carb boots so it's resting on top of engine case. Takes me longer to type all this than it does to remove carbs(bout 10-12min. job).81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
A stupid question ?
Have you pulled the plugs on #3&4 cylinder ?
Were they wet ? have you determined if there is spark ?Sometimes I use a caveman approach by squirting some raw gas into cylinder or cylinders with syringe .. reasonably simple way to eliminate spark/ compression questions ..If runs at all can be fairly certain fuel issue ..Good luck !78standard,79 & 80 Specials; 2 x 650 Maxims; 4 x RD350's; yz450; 2 x Honda tlr's;2x jt1 mini.Comment
The other thing is jetting - you'll need to adjust your jet sizes to accommodate the increased airflow with the pods. The jetting recommendations in tech tips will get you pretty close. And of course they'll need to be synched and adjusted properly.
And one other thing you'll want to do with pods. With the stock airbox the carbs are supported front and rear. A lot of folks will remove the airbox and just let the carbs dangle from the front carb hangers. They'll bounce around quite a bit that way, and it's not good for those expensive carb hangers. You can fashion a bracket for the rear of the carbs for support, and that makes for a much better installation without the bounce.I think I have a loose screw behind the handlebars.
