Here's my thing with XS clutches. The biggest PITA in the whole process is usually getting the old gasket off on the motor side. Sometimes you can get lucky and the old gasket can be reused. I got lucky with my brothers G this past summer that way. And then again, sometimes you can diddle-flock around with 'em for hours getting all the little pieces off and prepping the surface. And it's a lot easier to do with the basket out.
If you grease the new gasket, and it's not in too long, you can probably remove the cover again without damaging it if you find you need frictions after a spring change. But even if the gasket survives you'll still wind up having to deal with that star plate twice. That's two opportunities to break that little sucker, and it will break if you don't treat it right.
You can get a set of friction plates on Amazon for $39, including the shipping. And the additional work to install them when you've already got the basket exposed is hardly worth mentioning.
To me $40 isn't worth the potential aggravation of having to do the same job twice. Not to mention the peace of mind of knowing what's in your clutch. If $40 means more to you, then you have the option of trying to get by on the cheap. Just be aware that what appears to be the cheap way on the front end doesn't always wind up being the cheap way on the back end.
. Sorry, have NEVER been very fond of Yammys Three Bond associated with any of their numberings code
.......and have used them all decades ago.....lesson learned
. Sorry.....I just cringe everytime that numbering and name pop up on here!
