Valve Shims
  • Keithh
    • Jun 2011
    • 56
    • Chesapeake, VA.
    Valve Shims
    Greetings Folks! I'm doing some valve adjustments on my XS1100. I need a 240, 235, 250 shims (one each). Figured I check with the Noble XS11 Members before hitting other sources.
    Any assistance appreciated!
    Keith
    Current:
    1979 XS11F - "Sigmund"
    1975 Triumph T150V - "Ralph"
    1975 Honda CB125S - "Blue" - built for my daughter to learn on.
    1983 Kawasaki GPZ 550 - yet another bike that needs me! It followed me home...
    Previous:
    1975 Norton Commando
    1969 Triumph Tiger 650
    2002 Yamaha YZ250F
  • mack
    • 2411
    • Ontario, Canada
    I was warned
    but didn't listen. The problem with valve shims is that no matter what the best intent was, no one ever sends the old ones back. I've been burnt now a few times, the latest time by alaskey. We try to help out here but in this case I don't have the numbers you need, try rasputin.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      Yup.....
        Hey Keith,
        I just checked the limited spare set I have, and most of them were in the 280 range, found one 245 which is right in the middle of the range wanted, but not exact!?
        I don't know if any of the other LOCAL's would have any spares, but they might, try sending them a PM. And there's a newer semi local(Gloucester) fellow we(George and RichV and myself) met at the last XS Southeast rally. His username is Laruplus3 (Larry).
        Quick search shows this site as a source, note that Kawasaki and BMW also use the 29mm shims, so you might be able to get some "used" ones from a local dealer . http://newmotorcycleparts.net/motor_...lve_shims.html
        • Keithh
          • Jun 2011
          • 56
          • Chesapeake, VA.
          Valve shims
          Thanks TC - appreciate the look! I'll poke around to see what I can come up with.
          Keith
          Keith
          Current:
          Previous:
          2002 Yamaha YZ250F
            Keith,
            Be aware some other brands use a shim 29.5mm in diameter which do not fit so take along your caliper to be sure. Almost impossible to tell by eye.
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              Last time i needed one i paid about $7 at the BMW dealer on greenbriar in Chesapeake.
              I'll look at my stash tomorrow afternoon and get back.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
              • Wildkat
                XS Special Gurette
                • Apr 2004
                • 3416
                • Location, Location
                Well poop
                Checked my stash and I'm only good for 265 and up... I have a carp load of 265s if anyone is in need. lol
                We have a small bike shop close to us that will often trade shims. You might just need to call around locally to find one that can help you out while you try to find help online.
                81 SH Something Special
                79 SF MEAUQABEAUXS
                81SH Nor'eas tah (Old Red)
                80 LG Black Magic
                78 E Standard Practice
                James 3:17
                “Alis Volat Propriis”
                Yamaha XS 1100 Classic
                For those on FB
                  Alternative if it Helps
                  I bought my last shims from Jet-R-Us $6.69/ea + ~$8 shipping.
                  They are aftermarket shims, but they are fine.
                  • mack
                    • 2411
                    • Ontario, Canada
                    wildcat
                    your always a class act.
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
                      • 3193
                      I have 6 - 245's, 6 - 255's and 1 - 230. Closest I can come to matching what you need. Might tear apart another couple of bad engines and see what is in them, but that will be a few months so no help to you.
