When checking the rings, to measure the end gaps, you do that at the top of sleeve about 5/8 inch down, not the bottom right? Also the wavy oil ring's don't really wear out do they, it will always be the associated scrapers?
rings
rings
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None
Measure at both the top and the bottom of the stroke Mac. The cylinder will wear less at the bottom because it is lubricated much better. It'll give you some idea of cylinder taper wear.Greg
clymers
Pablo bought me a new manual. I hate to use it cuz its so shiny . My old one is missing pages so i washed my hands and cracked open the new one read the appropriate para's. My question about the little wavy oil ring still remains though.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186
As long as the oil ring spring (the piece between the 2 thin rings) isn't damaged it should be OK, in theory.
Don't like reusing rings.Greg
after
running the pistons through a couple cycles in the U/S cleaner it seems this motor was running very lean for a long time. Top of pistons are degraded. I have some spares I can put in so "new" rings it is. May explain how the valves got bent, I think the PO was playing with the timing. Maybe racing 1/4's with it. Who knows. It's my spare motor so no big deal.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186
Originally posted by mack View PostPablo bought me a new manual. I hate to use it cuz its so shiny . My old one is missing pages so i washed my hands and cracked open the new one read the appropriate para's. My question about the little wavy oil ring still remains though.Frame: 79 XS1100S
Engine: 81 XS1100S
Carbs: 78-79 BS34
Gf bike: 78 XS650S
Carbs: 70-79 BS38
