rings
  • mack
    • 2411
    • Ontario, Canada
    rings
    When checking the rings, to measure the end gaps, you do that at the top of sleeve about 5/8 inch down, not the bottom right? Also the wavy oil ring's don't really wear out do they, it will always be the associated scrapers?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Measure at both the top and the bottom of the stroke Mac. The cylinder will wear less at the bottom because it is lubricated much better. It'll give you some idea of cylinder taper wear.
    • mack
      • 2411
      • Ontario, Canada
      clymers
      Pablo bought me a new manual. I hate to use it cuz its so shiny . My old one is missing pages so i washed my hands and cracked open the new one read the appropriate para's. My question about the little wavy oil ring still remains though.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        As long as the oil ring spring (the piece between the 2 thin rings) isn't damaged it should be OK, in theory.
        Don't like reusing rings.
        • mack
          • 2411
          • Ontario, Canada
          after
          running the pistons through a couple cycles in the U/S cleaner it seems this motor was running very lean for a long time. Top of pistons are degraded. I have some spares I can put in so "new" rings it is. May explain how the valves got bent, I think the PO was playing with the timing. Maybe racing 1/4's with it. Who knows. It's my spare motor so no big deal.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
          • Blank Slate
            • Nov 2013
            • 393
            • Ottawa, Ontario, Canada
            The manual is just decoration for your shop, it doesn't really have any answers
            Frame: 79 XS1100S
            Engine: 81 XS1100S
            Carbs: 78-79 BS34
            Gf bike: 78 XS650S
            Carbs: 70-79 BS38
