Clutch problem
    Everyone, READ post #1 carefully BEFORE you throw another guess out there. Most particularly statements #1 & #2.
      • 2160
      I have been following and I have been expecting that something mechanical is jammed downstream of the clutch. I don't have any specific ideas, though.
        THANK YOU. Someone that gets it.
        He says the rear wheel turns fine in neutral so that would seem to rule out the FD and MD. Pretty much has to be something amiss in the transmission seems to me.
        • Aches n Pains
          • 349
          • Reston, Va.
          #34
          Thanks everybody.
          Finally got time to try your suggestions yesterday and she's running like a champ. I have a nice gentle downhill coming out of the garage. Got a little speed up, popped the clutch and (after a couple of trys) she broke free. Need to run her out for a while as she still has a little clutch shudder but I'm really happy with how she's running given how long she sat.
          Aches n Pains
          Doug
          1995 KZ100P
          Pods, jets, pipes, cam adjuster, oil cooler
          1977 Ironhead - custom build
          Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
          Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
          • red bandit
            • 970
            • central michigan
            #35
            Originally posted by BA80
            Like it may be going into 2 gears at once.
            +1 That's what I was thinking.
            79 SF parts bike.
            • robbo
              • 106
              • Aldershot. UK
              #36
              Seems like it was nothing more sinister than the clutch plates gummed up after being stood up for awhile. Glad you got it sorted
              Rob
              XS Eleven SF
              Could this be the finest Triumph Bonneville ever built ?
              (Cycle January 1979)
                Originally posted by Aches n Pains
                My bike has been sitting for a year and I'm having clutch problems. I assume the clutch plates are just stuck together. Spent quite a bit of time searching the site and am still confused.
                Symptoms
                1. On center stand, the bike starts nicely in neutral, warms up well and idles down nicely.
                2. When I try to put it in gear and let out the clutch she stalls. Wheel does not turn. Even if I blip the throttle when letting out the clutch.
                3. I have tried putting it in second or third gear and it stalls there also.
                4. There is plenty of oil in the engine.
                What am I doing wrong? I would expect the clutch plates to break free.
                Hate the thought of pulling the clutch plate.
                Thanks in advance
                Aches n Pains (Doug)
                This particular statement makes absolutely no sense if all it was is the clutch plates stuck. It should have not even gone into gear with the engine running without making a hellacious noise
                and the wheel should have most definitely moved.
                • aquamantx
                  • Aug 2015
                  • 198
                  • Montgomery, TX
                  #38
                  Ok, just because I like to understand things. The clutch plates and friction rings are stacked to provide enough surface friction to move the bike. If my clutch plates were frozen together would they not still transfer the output to the rear tire as you slowly release the clutch lever to apply the final force to the stack of clutch plates? A Standard car clutch is only one friction plate.
                  The next is could I not start the motorcycle in gear while on the center stand allowing the back tire to move freely? Have done this on a bike with a broken clutch cable.
                  Just trying to improve my knowledge.
                  81 LH in process
                  09 vstar 1300
                  only allowed 2
                    If the clutch wouldn't release..........the clutch wouldn't release. Pulling the clutch lever in would have no effect whatsoever, like with a broken cable. Slow, fast, sideways or upside down.
                    • aquamantx
                      • Aug 2015
                      • 198
                      • Montgomery, TX
                      #40
                      I agree. Thats why I mentioned starting it in gear on the center stand. If it was a stuck stack the starter should have enough force to rotate the suspended rear wheel.
                      81 LH in process
                      09 vstar 1300
                      only allowed 2
                        try to turn it over in gear with the clutch ENGAGED. If it is mechanical the engine won't turn when the starter engages.
                        Clear as mud?
                        Something like this?
                        • aquamantx
                          • Aug 2015
                          • 198
                          • Montgomery, TX
                          #42
                          Yep. I guess I lost that in the thread.
                          81 LH in process
                          09 vstar 1300
                          only allowed 2
                          • ViperRon
                            • Feb 2011
                            • 1062
                            • Woodstock, VA
                            #43
                            Wow Greg them mechanics of the XS11 have majic smoke in them just like the electronics.
                            Rodan
                            1980 G Silverbird
                            1198 Overbore kit
                            Grizzly 660 ACCT
                            Barnett Clutch Springs
                            R1 Clutch Fiber Plates
                            122.5 Main Jets
                            ACCT Mod
                            Mac 4-2 Flare Tips
                            Antivibe Bar ends
                            Rear trunk add-on
                              Just thinking out loud here....Is there a kick stand safety switch that could cause that problem?
                              Not on either of those three listed.
                                • 735
                                Thanks, That must have been my Virago XV1100 that I was thinking about,.
