Long day
  • mack
    • 2411
    • Ontario, Canada
    Long day
    I don't know how many of you saw my little video of the tear down of this E, but in it you'll see a couple stills of the carbs that came off it. They were the skankiest carbs i've ever seen. Anyway today i thought I'd see if they could be salvaged. After reoving the diaphrams and slides, I split the rack and started to take them apart. The only thing that came out easily was the diaphrams and slides.
    3 of 4 pilot tower plug screws were broken off and rusted in place. (drilled them out) 4 of 4 pilot jets had to be drilled out, all 4 idle mixture screws were broken off, 3 of 4 pilot air jets needed to be drilled out. 3 of four starter jets were rusted closed. All the butterfly screws were rusted in place and had to be drilled out to remove the butterflys. All the shaft seals were deteriorated and most of the shafts are bent. The bowls had all rusted completely through in the lowest corner(it was on it's side stand for 15 years)Carb tops I just remove the bolts with vice grips and threw the tops and screws in the garbage.
    But, with much patience and endurance, I now have four useable stripped bodies to work on tomorrow ,to see if I can unplug all the passages form rust.
    I have enough spare parts to get a good set of working carbs together if I can get the passages clear.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • MPittma100
    • Aug 2011
    • 2359
    Carbs
    Would be nice if you could have them put in an ultrasonic cleaner.
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Mack
      I have no doubt in your technical ability but how much pain are you in for, I'd say a lot. Me knowing how I am every time I had a problem it would be those carbs. Personally I'd only give them one shot at working, clean them, triple check everything and if there are problems strip the good parts and scrap metal bucket the rest. If there is that much rust inside and things bent it's gona be a pain in the ass to get a smooth idle and I'd bet low speed sync will be off from mid speed. I do wish you luck and empathy.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • mack
        • 2411
        • Ontario, Canada
        Cleaner
        Pitman-I have a 20 gallon "branson" ultrasonic cleaner. They will spend the next few days cycling in and out of that with liberal amounts of compressed air after each cycle. Right now they are soaking in a vat of metal rescue.
        Ron- I hate to give up on anything. Patience is everything when doing anything with these bikes. If it doesn't come apart or go together easily then your doing it wrong. With these carbs, there are some tricks I've found over the years that help, but the most important is that as soon as you find that what your trying isn't working, quit right away and try a different technique before you destroy what you have to work with.
        I'm sure I'll get the passages clear, what concerns me is , when ever you remove a broken idle mixture screw tip, the metering hole is distorted to some degree. Finding the right adjustment under running conditions will be difficult without a colour tune or a very good ear. The ability to count turns on the screws is gone. The tip of a new screw will have to extend into the throat more than usual so if where 1 1/4 turn was factory settings, these may be 1/4 turn and all will be different.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • Roncoach70
          • Aug 2015
          • 84
          • Myrtle Beach, SC
          Mack,
          Your amazing. I commend your persistence. Great job!
          79 XS1100SF
          79 XS1100SF parts
          79 RD400F Daytona Special
          • ViperRon
            • Feb 2011
            • 1062
            • Woodstock, VA
            Mack as I said I have no doubt in your ability or persistence but you are like a few here exceptional in technique and persistence because of experience.
            So if I got a bike and did all this and sold it to you what would you call me when you had to retune it.
            Rodan
            1980 G Silverbird
            1198 Overbore kit
            Grizzly 660 ACCT
            122.5 Main Jets
            ACCT Mod
            Mac 4-2 Flare Tips
            Antivibe Bar ends
            Rear trunk add-on
            • mack
              • 2411
              • Ontario, Canada
              No worry's
              That's not my style Ron, these carbs will get buried with me. I would never let them out of my shop incase the new owner wasn't up to speed on tuning these carbs. I will however throw them on my SF next summer and see how they perform. If it's good then I'll keep them on it and make my originals available for guys that need them. Win win for everyone!
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
              • mack
                • 2411
                • Ontario, Canada
                Oh
                and pitman- I meant 20 liter/5 gallon branson cleaner.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                • ViperRon
                  • Feb 2011
                  • 1062
                  • Woodstock, VA
                  You are a good man Mack.
                  Rodan
                  1980 G Silverbird
                  1198 Overbore kit
                  Grizzly 660 ACCT
                  122.5 Main Jets
                  ACCT Mod
                  Mac 4-2 Flare Tips
                  Antivibe Bar ends
                  Rear trunk add-on
                  • mack
                    • 2411
                    • Ontario, Canada
                    Passages
                    Passages are all clear and I've got great velocity with the compressed air. Some staining in the barrels from the "metal rescue rust removal, but while the stain is still there after polishing them, the barrels are smooth as a babies bottom. Very happy at this point.
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
                      Mack, you definitely have good patience and persistance taking on a set of carbs in that condition! hope they can end up salvagable and tuneable when back together!
                      • mack
                        • 2411
                        • Ontario, Canada
                        throttle shafts
                        I worked on them today. I had a piece of steel that was the right thickness and had to use a hack saw to cut it to width. Arm is pretty sore right now. Anyway I clamped that into a vice and slipped the shafts over that, then double nutted one end and was able to turn the nut and twist the shafts back into place without distorting the butterfly slots. I'll debur them tomorrow and check the fit and alignment. Funny thing with these. I absolutely know these carbs are original to the bike and the needle jets (emulsion tubes) are all 4-4-4-4 on all carbs. The PO never tampered with them. This is the third set I've see with that config of emulsion tubes.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
