I don't know how many of you saw my little video of the tear down of this E, but in it you'll see a couple stills of the carbs that came off it. They were the skankiest carbs i've ever seen. Anyway today i thought I'd see if they could be salvaged. After reoving the diaphrams and slides, I split the rack and started to take them apart. The only thing that came out easily was the diaphrams and slides.
3 of 4 pilot tower plug screws were broken off and rusted in place. (drilled them out) 4 of 4 pilot jets had to be drilled out, all 4 idle mixture screws were broken off, 3 of 4 pilot air jets needed to be drilled out. 3 of four starter jets were rusted closed. All the butterfly screws were rusted in place and had to be drilled out to remove the butterflys. All the shaft seals were deteriorated and most of the shafts are bent. The bowls had all rusted completely through in the lowest corner(it was on it's side stand for 15 years)Carb tops I just remove the bolts with vice grips and threw the tops and screws in the garbage.
But, with much patience and endurance, I now have four useable stripped bodies to work on tomorrow ,to see if I can unplug all the passages form rust.
I have enough spare parts to get a good set of working carbs together if I can get the passages clear.
! hope they can end up salvagable and tuneable when back together!
