seeping front calipers
  • mack
    • 2411
    • Ontario, Canada
    I rebuilt the front calipers as part of the restore of this E. The caliper bodies were cleaned ultrasonicaly and the recess for the o ring that seals the piston was spotless. I've noticed a small pond under the left side rotor. At first I thought it was just excess cable lube dripping from the speedo connection, but today I got down on my back and looked at everything closely. It appears like the leak is coming from the caliper pistons. The rebuild kits were from "tour max". I did notice at the time of installation that the pistons seemed to slide in and out rather easily compared to the special's I did. Anyone ever experienced this before. I had a heck of a time with the rear master cyclinder rebuild kit as well. Also by "tour max", it took 3 kits before one worked properly.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 3954
    I think I got mine from Georgefix. If they slid-in too easily, sounds like that seal may be faulty.
    • MPittma100
      • Aug 2011
      • 2359
      Leak
      +1 on Georgefix. Considerable resistance sliding piston into caliper should felt.
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
      • mack
        • 2411
        • Ontario, Canada
        Ya
        thats the way the special were. Took some considerable effort to get the pistons in far enough to fit over the rotors. I'm never buying tour max anything again!
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
