Hi Guy's I've been dealing with this problem for a couple of weeks and I can't seem to figure out who the culprit is.
I will be driving along or sometimes i'll be stopped and the bike will just shut off. the lights will stay on but if I try to hit the starter nothing happens. The only way I can get it to start is by touching and there by connecting the starter solenoid bolts with a piece of wire or a screw driver the solenoid sparks a bit then the starter begins to turn over. I take the conductor away and the bike will fire right back up with the starter button. Usually though once it happens it happens again and again and again with the time shortening between each occurrence.
it' happens totally randomly sometimes it's when I first start ridding other times like tonight it happened as we were coming back from a thirty minute ride. before a couple of weeks ago i put almost 900 miles on the bike before it happened again.
has anyone ever seen this before?
