LED Replacement Bulbs
  • ardvark1
    • 135
    • Midlands UK
    Are ALL or some led replacement bulbs directional? Reason for asking is that headlight bulbs face forward and the indicators bulbs face sideways. This may seem a daft question but if you don't know you don't know.
    Al
    • 3918
    Howdy Al- It's a good question that's been touched-on before. If you do plan-on buying LED bulbs, and do not want to get into directional bulbs, find one's with a rotating base. But, taillight, blinkers, and headlight should be your concern. The dash bulbs will illuminate no matter what direction (BA9). My bike is all-led, all the way around. Only thing I have to do is possibly wire-in a license plate light, as you lose that feature going from a white incandescent, to a red LED taillight bulb.
    • ardvark1
      • 135
      • Midlands UK
      Hi Ian,
      One of the things I'm thinking of is using a set of indicators fitted to the forks and using them a permanent driving lights. The bulbs in the indicators are mounted sideways, that is the reason of me question. Also if I use the indicator as a driving light a led bulb will be much cooler than the conventional bulb and hopefully will not overheat and blow.
      Al
        • 3918
        I guess I'm confused as to your question at this point. The XS11 used 1157 bulbs up-front, which allow them to operate as day-runners, as-well as turn signals. If you plan-on being more visible up-front, I'd suggest flood driving lights.
        • ardvark1
          • 135
          • Midlands UK
          I'm thinking flood lights being aesthetically to big but factory indicators being not to out of place.
          Al
            • 3918
            Fuction over form if you're thinking safety. I have floods on mine, and I love them!
            • ardvark1
              • 135
              • Midlands UK
              Dare I ask for a pic of them on you bike?
                Well since Al has a SF, his front turn signals are not 1157 bulbs. The specials only have 1156'S in theirs.
                I too would agree though with Ian, the turn signal indicators would be totally useless as driving lights. They just would not put out enough light to be of any value.
                • ardvark1
                  • 135
                  • Midlands UK
                  You both have the advantage over me on this subject. So no matter which LED bulb I put in the indicator body you say it would'nt be bright enough?
                  Over here we have right muppets and window lickers driving on our roads. I'm thinking along the lines of 3 lights on the front being better than one.
                  Al
                    Nope, there just isn't enough reflectivity inside the housing and leds are too directional to produce enough light, and the lens is just not designed to be used with leds.
                    Your best bet is tool find some purpose built driving lights.
                      Hi Al,
                      These work really well.
                      LED pod light / work light emits cool white light in a 60° beam pattern and is ideal for use in marine, off-road, and industrial settings. Built with IP67 rated waterproof aluminum housing to with stand harsh environments and weather conditions. Includes an integrated heat sink designed to optimize the life of the light by dissipating heat and keeping the LED cool. Stainless steel installation hardware and mounting brackets are included.
                      They also have a 2" round unit but it puts out less light and costs more but may suit your quest for small driving light.
                        • 3918
                        Ask the Lost Rally riders how they perform . . .
                        • ardvark1
                          • 135
                          • Midlands UK
                          Now that is a nice bike.
                            Hey Al,
                            What the others have said are what I have also said several threads ago!
                            Here's MY BIKE with them mounted to simple L brackets bolted to the lower fork TT clamp/bolts!
                            My headlight looks funny because I have an Mini HID projector mounted inside of it. These lights do put out quite a bit of light which also aids in seeing the road at night, as well as being very visible during the day. They are LED's so they only draw a total of 1 amp each. But they are a bit expensive like $35.00 each! But will provide what you're looking for and more...both visibility to others as well as visibility in seeing the road at night!
                            I got them from the site linked to in the previous post.
                            • ardvark1
                              • 135
                              • Midlands UK
                              Now if I can get stock indicators to have LED bulbs inside them to put that much light out along with the headlight. That is the look I'm after. Question IS, can I get what I'm after?
                              Al
