Not sure what you mean by "the primary leads". The wires leave the pickup coils sealed, and are not exposed to a connector until they hit the TCI, AFAIK. There is no place to test the wires inside the timing cover unless I cut the wires.
Intermittent loss of power
-H. Ford -
The primary leads on the ignition coils - not the pickup coils. Unplug the orange, grey, and red/white wires from the coils and check the resistance without going through the wires that run from the TCI.I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
Oh! Ok, will do that.1980 XS850SG - Sold
-H. FordComment
In the last place that you look
Catatonic bug, I had a weird problem once where it wasn't the pickup coil wires near the coils themselves ...but where they come into the pigtail near the shifter area , frustrating until I figured it out !!! also have a different 11 that right handlebar switch wires would partially disconnect under the gas tank ...78standard,79 & 80 Specials; 2 x 650 Maxims; 4 x RD350's; yz450; 2 x Honda tlr's;2x jt1 mini.Comment
power loss
I was having a similar sounding issue. going along just fine then it's like I'm running out of fuel. couldn't figure why it would do this. then i remembered a riding lawn mower that did the same thing. So the next time it happened I opened the gas cap.and closed it again. problem solved I think on some days in the heat the tank gets a vapor/pressure lock. It might be this simple.
81 1100 special
79 1100 special
Loud pipes draw copsComment
I think I've determined that my digital meter doesn't do ohms very well. I re-checked the coils, and struggled to get a reading at all, using alligator clips on the metal terminals in the plug caps. As soon as I switched to my analog meter, the reading was a crisp and solid 21-22k ohms, on both coils. I know that's high for the numbers you provided, but could that just be because they are Accel coils?
I checked the wires that run from the TCI to the coils, and got 0 ohms on all connections. I checked the red/white wire from the TCI to the kill switch, at the connector under the tank, and get 0 there too. I checked the connections at the tip over switch, and all are 0 ohms, except for one, that gets 3 ohms (diagram says it runs to a resistor?).
The one strange thing I noticed - when re-checking the black/white wire at the TCI, it starts with 0 volts, then I turn the key on, and I get 1.3v for about 5 seconds, when I hear a faint "click" (some kind of relay, happens every time) and it drops to 0 again. Turn the engine on, and it runs at under 1v. Since this is only for the tip over switch, I get a feeling it doesn't need much to signal that the switch has been activated. The other end of the tip over switch connects to the grounds for the tach light and headlight indicator, both of which are now LEDs on my bike. Could that explain the lower voltage on that wire?1980 XS850SG - Sold
-H. FordComment
I also re-ran the primary resistance check (red/white wire in the TCI connector to the gray, then to the orange), and got 0 ohms on the analog meter. Not sure why, but the digital meter still shows 7 on both. You said I should be getting 3 ohms on that test though. If there is no resistance, where SHOULD the resistance be created?1980 XS850SG - Sold
-H. FordComment
When I check my Dynas I get 12.54K ohms on the secondaries when they're cold, and I'm thinkin' 21-22K ohms is too high, but I don't know for certain on the Accels. Were your coils cold when you checked them? Do you know what the model number is on your Accels?I think I have a loose screw behind the handlebars.
Also, on the black/white showing low or zero voltage. It shouldn't make any difference what it's hooked up too. You're basically shorting that wire out before it gets to the emergency stop switch so it's telling you the TCI isn't supplying the six volts of power on that line that it's supposed to. The manual says if you're not getting close to the voltages it mentions, and the black wire shows continuity when you ground it, then the problem is in the TCI. Or maybe it would be more accurate to say that the TCI has a problem.I think I have a loose screw behind the handlebars.
Are you sure your dmm was reading 7 ohms, and not .7 ohms? Accel's 140403 coils are supposed to be 3 ohm coils, but their 140404 coils are .7 ohms - and they look identical. I read at least one account of a guy using the 140404's on a Suzuki GSF1200 that were sold to him as 3 ohm coils, when in fact they're .7 ohms. He said it "cooked his igniter." If it was mine, I'd be checking the model number on those coils.I think I have a loose screw behind the handlebars.
Are you sure your dmm was reading 7 ohms, and not .7 ohms? Accel's 140403 coils are supposed to be 3 ohm coils, but their 140404 coils are .7 ohms - and they look identical. I read at least one account of a guy using the 140404's on a Suzuki GSF1200 that were sold to him as 3 ohm coils, when in fact they're .7 ohms. He said it "cooked his igniter." If it was mine, I'd be checking the model number on those coils..
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
For the purposes of checking the coils, I agree. The manual tells you to check the resistance at the TCI and I suspect that's because the TCI is evidently the thing that's sensitive to the resistance. I've got a funny feeling his actual reading was .7 ohms, but I'd like to see him verify that at the coils. If it turns out to be the case it would explain a number of things.I think I have a loose screw behind the handlebars.
CBug - when you check the coils the model number should be right on the Accel sticker on the coils.I think I have a loose screw behind the handlebars.
I also re-ran the primary resistance check (red/white wire in the TCI connector to the gray, then to the orange), and got 0 ohms on the analog meter. Not sure why, but the digital meter still shows 7 on both. You said I should be getting 3 ohms on that test though. If there is no resistance, where SHOULD the resistance be created?I think I have a loose screw behind the handlebars.
All I can be sure of is that the digital meter says 7 ohms, without a decimal, but the analog meter swings all the way to zero. Since the analog meter is brand new, I tend to believe it more than the digital one in this case. The way the dial reads, there is no mistaking the low readings (below 5 ohms), since the numbers get closer together as the value rises. If it was .7, it would be visible.1980 XS850SG - Sold
-H. FordComment
