bogs once in a while
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    Carbs were cleaned and inspected over this past winter by a novice bike mechanic. Has brand new plugs (whatever the XS1100 recommended NGK's are). Recently there have been a couple times when the bike feels like a slight bog. Almost like when you're running out of gas. Seems to happen at lower rpms with partial throttle. I'll hear a little pop, like a misfire and will be a little sluggish. I'll get to my destination, hang out for a bit and then all of a sudden she's running great again. These are not long rides and temps are about 75-80 here in NJ.
    Been using 89 octane (because some swear by 87 and others by 92/93 so I'm splitting the difference )
    New inline fuel filter was installed over winter.
    Any ideas?
    Where should I start troubleshooting?
    Rob - 79 SF
    Any ideas?
    a 'novice mechanic was my first clue. Actuallt the idle mixture is set too rich.........if it was re-set at all.
    • mrhammer2u
      • Aug 2014
      • 472
      • Northern, NJ
      Yea, I mentioned novice because I'm finding a few things he did were shotty. However I can't talk because he's more capable than I. Not saying much.
      You seem pretty sure of your answer. I'll try and find a way to adjust myself. Would that explain the intermittent bogging? Wouldn't it always bog?
      Rob - 79 SF
      • mrhammer2u
        • Aug 2014
        • 472
        • Northern, NJ
        Oh hell,...there's 4 of them buried in the carb? I'm sure it's not as easy as reaching in there and turning each one a few ticks. Then I gotta re-sync right??
        Who's great idea was 4 freaking carbs???
        Rob - 79 SF
          • 8864
          Maybe blocked gas cap vent. When it bogs, you could try opening the cap, make sure tank is not topped off. Or, just clean it.
            • 9980
            It could be an intermittent pick up coil wire issue too. Mine did that when one started to break. Sometimes it would make contact and work for miles then 2 cylinders would cut in and out at random times.
              Bettin' there's alot more he missed..........or likel doesn'r even know about. Come here if you want CORRECT answers, not a sometimes wrench-turner novice.
