Doc got his SG out of a field, dragged it home and started fixing it. First thing was the engine was locked up so he spent a long time soaking the cylinders with penetrating oil and working to bust it loose.
Finally got it loose and everything fixed and working but it always used a lot of oil and gas.
Last spring he lost #1 cylinder and parked it. I figured he had broken a ring as bad as it used oil.
He purchased one of those $150 BB kits from ebay and it showed up the other day so today we proceeded to tear down the top end.
First thing when the head came off we found a BADLY burnt exhaust valve in #1 cylinder. So, there is the lost #1 cylinder.
But, that still didn't explain the oil consumption. 3 of the 4 pistons were washed well back from the edges so it was obvious the rings weren't sealing properly.
We pulled the cylinders and it was obvious why. The cylinders were rust pitted from sitting and seizing up.
Off to the machine shop to get the 1196 pistons fitted and the head repaired.
I know that several people here were curious about those inexpensive BB kits on ebay so I started this thread to take y'all trough it and we'll all see how it turns out.
(Sold back to Maximan)
My thinnest feeler guage is .002" and the ONLY lobe it would slip into was #4 exhaust.
