79' 1196 cafe r1 swap project
  • drshankles
    • Feb 2013
    • 34
    • rancho santa margarita, Ca.
    -1979 XS1100SFCAFE CHOP
    WEISCO 1196CC KIT
    SMOOTHED FRAME WELDS
    YZF-R1 COMPLETE FRONT END
    DYNATEK 3 OHM COILS
    MIKUNI RS36 CARBS
    FIBERGLASS TAIL
    YAMAHA YZF-R1 REAR SETS
    LITHIUM BATTERY
    -1979sf donor bike (sold)
    -1979sf restored to factory
    -1986 gsxr750r (sold)
    Dry clutch
    4 degree timing plate
    3 ohm Dynatek coils
    Dynatek hight output ignition
    Original 80's 4-1 Yoshimura full exhaust
    -1994 Ducati 900ss track bike(project)
    Lots of stuff
  • drshankles
    • Feb 2013
    • 34
    WEISCO 1196CC KIT
    DYNATEK 3 OHM COILS
    MIKUNI RS36 CARBS
    FIBERGLASS TAIL
    LITHIUM BATTERY
    Dry clutch
    3 ohm Dynatek coils
    Lots of stuff
    • drshankles
      • Feb 2013
      • 34
      WEISCO 1196CC KIT
      DYNATEK 3 OHM COILS
      MIKUNI RS36 CARBS
      FIBERGLASS TAIL
      LITHIUM BATTERY
      Dry clutch
      3 ohm Dynatek coils
      Lots of stuff
      • drshankles
        • Feb 2013
        • 34
        WEISCO 1196CC KIT
        DYNATEK 3 OHM COILS
        MIKUNI RS36 CARBS
        FIBERGLASS TAIL
        LITHIUM BATTERY
        Dry clutch
        3 ohm Dynatek coils
        Lots of stuff
          • 4015
          Wow! Flat slides, ehh? Tried those on my 850, and just could not achieve satisfactory street-riding performance. Obviously they're meant for the track (WOT performance).
          Absolutely beautiful bike! I'm diggin' the simple gold & black! Are those "RAASK" rearsets, or custom-made? I'm impressed with the work, yet surprised you stayed with stock rear springs (or are those Progressive)? Interesting rear MC setup, yet caliper and rotor are stock. Looks clean!
            • 6765
            Wow indeed...very few pull it off so well...but I personally couldnt ride it...
            2005 Honda SilverWing 600
            2018 Honda PC-Xpress 150
            • drshankles
              • Feb 2013
              • 34
              rear sets
              These aren't raas rear sets but do have a set and didn't like the look on this build. The sets are from a 2002 yamaha r1 there factory. A lil modification and spacers with the factory brembo Mc and brake line bolts right up
              WEISCO 1196CC KIT
              DYNATEK 3 OHM COILS
              MIKUNI RS36 CARBS
              FIBERGLASS TAIL
              LITHIUM BATTERY
              Dry clutch
              3 ohm Dynatek coils
              Lots of stuff
              • CaptonZap
                • Jun 2010
                • 1748
                • Denver
                Where did you hide the battery and TCI?
                CZ
                • drshankles
                  • Feb 2013
                  • 34
                  Electronics and wiring
                  The tci is under the tank with fuse block and regulator. Wiring is rerouted between carb 2 and 3 intake boots, battery is under tail section it is a sealed lithium ion battery mounted upsidedown. Ing. Switch is deleted and have one momentary, one spst switch, and a hidden kill switch that is a magnetic contact.
                  WEISCO 1196CC KIT
                  DYNATEK 3 OHM COILS
                  MIKUNI RS36 CARBS
                  FIBERGLASS TAIL
                  LITHIUM BATTERY
                  Dry clutch
                  3 ohm Dynatek coils
                  Lots of stuff
                  • drshankles
                    • Feb 2013
                    • 34
                    To do's
                    Still event finished paint, also have no gauges but am welding in 2 2 inch sight glasses one at base of tank by mount bolt andbone under tank that will be lit up by an led so the fuel will glow to view fuel level. Have to finish headers and install the mikuni rs36's than time to fire her up I guess. Oh and upholstery, new tires yadda yadda... more than happy to share how I did things so if anyone has questions. Thus far I have used only hand tools and an angle grinder to get the bike this far, so if anyone thinks they have to have all sorts of expensive tools to build a bike that's not true. Just alot more time and elbow grease.
                    WEISCO 1196CC KIT
                    DYNATEK 3 OHM COILS
                    MIKUNI RS36 CARBS
                    FIBERGLASS TAIL
                    LITHIUM BATTERY
                    Dry clutch
                    3 ohm Dynatek coils
                    Lots of stuff
                    • drshankles
                      • Feb 2013
                      • 34
                      Rear shocks aren't in yet
                      WEISCO 1196CC KIT
                      DYNATEK 3 OHM COILS
                      MIKUNI RS36 CARBS
                      FIBERGLASS TAIL
                      LITHIUM BATTERY
                      Dry clutch
                      3 ohm Dynatek coils
                      Lots of stuff
                      • TallBob
                        • Sep 2011
                        • 160
                        • Greensburg, PENN.
                        Great looking bike! What all was involved and how difficult was it to retrofit the R1 triples and forks to the XS11 frame? Was the fork assembly also from a 2002 R1? Thanks, Bob
                        • TADracer
                          • 1417
                          • Kenner, Louisiana USA
                          I couldn't ride it either...damn knees! But I am impressed and I like it!
                          Mike Giroir
                          79 XS-1100 Special
                          • drshankles
                            • Feb 2013
                            • 34
                            The swap was fairly simple, everything swaps straight over except for the top bearing. That needs to be sourced.
                            And trimming the bearing seals from the R1 to work with the xs bearings and neck.
                            WEISCO 1196CC KIT
                            DYNATEK 3 OHM COILS
                            MIKUNI RS36 CARBS
                            FIBERGLASS TAIL
                            LITHIUM BATTERY
                            Dry clutch
                            3 ohm Dynatek coils
                            Lots of stuff
                            • drshankles
                              • Feb 2013
                              • 34
                              Thankyou everyone really appreciate it.
                              WEISCO 1196CC KIT
                              DYNATEK 3 OHM COILS
                              MIKUNI RS36 CARBS
                              FIBERGLASS TAIL
                              LITHIUM BATTERY
                              Dry clutch
                              3 ohm Dynatek coils
                              Lots of stuff
