I get the feeling my speedometer is off and my tach is jumpy . Can any one tell me what rpm is normal at 35mph and 80mph. Might even be interested in buying a new set of gauges for my 79F. Don't care what they look like as long as their accurate, functional, and not smashed to all hell. Pm me here or text to 406-670-8632. Thanks for your time
Mph vs rpm
Tags: None
With a 750 FD my '79F is doing 3800 rpms at 70 mph in fifth gear. Just checked it a couple weeks ago. With the stock FD it should be somewhere around 4400 rpms at 70.I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake lines -
Hey, Ranger ...
When Cycle tested the '78E, they had a reading of 3,790 RPM @ 60 MPH.
Assuming you have the stock FD and 17" rear wheel, your F should be the same.
You could use this as a baseline to determine if your gauges are functioning properly.
But, if your tach is "jumpy", it may be difficult to get a good RPM reading at any given speed.Marco
1979 Honda CBX
2002 Kawasaki ZRX1200R
WE MISS YOU, DONComment
I get the feeling my speedometer is off and my tach is jumpy . Can any one tell me what rpm is normal at 35mph and 80mph. Might even be interested in buying a new set of gauges for my 79F. Don't care what they look like as long as their accurate, functional, and not smashed to all hell. Pm me here or text to 406-670-8632. Thanks for your time. Plug them back together and try it again
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
New or different speedo won't fix the issue. Try pulling the fuse panal and unpug that smallest plug-in with the two tiny pin type plug-ins. 'don't care what they 'look' like, clean BOTH plug-in contact surfices till they schine. Plug them back together and try it again
. BTW, these particular brand/model tires even though the 90series match perfectly with original sizes.
Last edited by motoman; 09-17-2015, 08:18 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Thanks
Thanks for all the info, you guys were right. It's the tire, had a buddy follow me and checked the tach vs speedo and its consistent.79 XS11 FComment
. In fact, you BETTER unplug and clean ALL rhose plug-ins behind fuse panel, as alternator stators are NOT cheap!
Last edited by motoman; 09-19-2015, 11:14 AM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
