Did the '78E, '79F, '80G, and '81H all use the same handlebars? Was searching online and the info seems a little sketchy.
Handlebar Interchange
Pretty sure the answer is yes. I looked high and low for a set of stock bars to replace the bent ones on my '79F, but everything I found was either rusty or bent. I finally found a pretty close match, and I started a thread when I first got them installed with the details and pics - Finally found bars I likeI think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake lines -
There has been rumor that the '81H had a slightly taller barwith the same profile as the other years. Supposedly this was to clear the taller tank.Nathan
Theodore RooseveltComment
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Thanks guys, appreciate the info.Billy
1982 XJ1100, Ceramic Coated Headers, Raptor ACCT, Barnett Clutch Springs, Dremmel Fix, TC's Fuse Block, De-Linked S/S Brake Lines, 850 Final Drive, Yahman's YICS Eliminator, Pods, stock jetsComment
Hi Billy,
I have been told the older Gold Wing bars fit the standard.
I think that is what is on my 81H but have never been able to confirm.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
