I tell you
  • Jeffintampa
    • Apr 2011
    • 344
    • Zephyrhills, Florida
    I tell you
    Well, since he is all back together been riding to work. As I was pulling into my parking space it died no power all lights out bump back on just a hick up. I got on rode almost all the way home, perfect then died no power. I put a new battery and cleaned all the grounds great. I went out and no power now, tested battery ok got power to the part the pos cable bolts to.
    what the heck
    Bike History:1980 XS 1100 special current bike
    1980 XS 850 special wife sold
    Check the main power wire from the battery, it may be broken making intermittent contact. And it's connector.
    Also the main fuse.
    • tcoop
      • Nov 2009
      • 793
      • South Weber, UT
      I had the same issue - the bike would die for no apparent reason, then started working again. I found the issue to be crimp job I did on the new fuse box ( I apparently suck at crimping, I used cheep crimping tool) I need to buy better tools
      Ty
      78 XS1100E - Now in Minnesota
      80 XS1100LG - The Punisher
      82 XJ1100 - Daughter's Bike
      • kevxs
        • Apr 2009
        • 353
        • toronto
        i had a similar issue, problem ended up being the big white electrical connector behind the fuse box, the connectors were in desperate need of a good cleaning.
        1979 XS1100SF 37000km
        Green Dyna Coils
        Stainless Brake Lines
        1973 CB100
        kevXS
        • Jeffintampa
          • Apr 2011
          • 344
          wiggle jiggle
          Well seat off wiggle jiggle everything and it seems to be coming from that wire connector that goes over or beside the air intake rubber got it to turn and off by moving that around
            Pickup coils?
            • Jeffintampa
              • Apr 2011
              • 344
              got her figured out
              Well pretty sure I found it. I was getting the dying while wiggling the two red wires that go over the rubber air intake. Well I pulled the rubber fuse holder and one fuse had the end off, two new fuses and seems to be the fix
                Hey Jeff,
                Good find! That's the separate MAIN fuse that Yamaha put on the other side of the bike vs. the fuse panel! Mine was also a GLASS fuse, I got a SOLID ATCO style holder and put it on in place of the glass one! Would highly suggest you do the same in the near future. You'll want to get one with some 10-12 gauge wire and can handle 30 amps!
                  Originally posted by trbig
                  Pickup coils?
                  Doubtful..............likelyhood of faulty connections is MOST likeley as BA80 stated.
