petcocks
  • mack
    • 2411
    • Ontario, Canada
    petcocks
    I rebuilt the gas tank and petcocks for this E, I spent the last couple days with fuel in the tank watching for leaks with them on RES. Once I was satisfied the petcock/tank gaskets were not leaking and no fuel was dripping from the diaphram screws I was draining the tank. I didn't have vacuum hoses hooked up just had gas line on them, when I switched the selector to on I got fuel pouring out of these holes.
    Am I correct in assuming that this would be normal and after the vacuum lines are hooked up, I won't see anymore leaks?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • red bandit
    • 957
    • central michigan
    With NO vacuum applied you should NOT have any fuel flowing/leaking when in the ON or RES position. Fuel WILL flow in the PRIME position with or without vacuum applied.
    79 SF parts bike.
      Hey Mack,
      I'm pretty sure that those little holes are just vent holes to allow the vac. diaphragm to be able to move back and forth. I think I remember reading something about the Octy with similar design, and that there was a right way and wrong way to put the square/rectangular diaphragm in place for it to work right. I have a standard tank but haven't messed with it or it's petcocks. Hopefully someone else will post about it?
      • mack
        • 2411
        • Ontario, Canada
        Ok
        i was afraid of that, I'll pull them apart tomorrow and check that out. Worked all day on a leaking #3 carb i want to use on the bike, but it won't stop. Changed the float settings, changed the float, changed the inlet valve and needles three times (all mikuni) still won't hold. I've got a couple spare #3's here that I'll split the rack and replace it. When I have more time I'll look at it closer to see what the issue is. Reminds me of awhile back someone else had this problem and went in circles for days, then I think he just sold the bike. I want to get this e running before the seasons over.
        The petcock internals are all new so it won't take long to change them around.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • mack
          • 2411
          • Ontario, Canada
          Petcocks
          Well I'm sorry to say that there was nothing wrong with my assembly technique. I pulled them apart and all was good. The issue is that the kit came with defective parts. The small shaft with the o-ring on the end that fits into the petcock body is not long enough to seal the chamber. Thus no matter how much I pushed on it manually, it won't make contact. So, I'm looking at a pingle conversion kit. Never liked the whole plumbing thing anyway. All I want is on/off gravity flow! Does anyone have a number for the correct one for a standard?
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
          • Lance Skene
            • Aug 2015
            • 8
            • Irricana Alberta Canada
            I just put a new selector gasket and fuel pump o ring yesterday, pump diaphram can go two ways, theres a tiny vent groove in the plastic that I put to the top side, petcock will drain from the forward line if its 'on' or 'res', or drain from the rear line if at 'prime'. Mine was dripping from both lines while off and priming the left side carbs while parked but changing the gasket fixed that.
            83 XJ11 Maxim Canadian
            • mack
              • 2411
              • Ontario, Canada
              Lance
              Our petcocks are different from each other
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
