There are two sizes for the metal on metal needles. One is 17.5 mm for later carbs and the other is 15.1 mm for the early carbs. I can't find any source that gives the measurement so I know I'm getting the right ones. Anyone have a source? Also I'm looking for the small rubber washers for the later idle mixture screws.
float needles
float needles
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
Niche Cycle Supply has a good assortment of Mikuni parts, but you need to know the Mikuni part number you're looking for.I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake lines -
This was what worked on my XJ carbs...from a post I started a couple years ago -Motoman told me the o-rings are still available from Suzuki, part number is
13295-29900. He was right, I'm looking at 4 of them now. Maybe the part number should be included in the Carb Cleaning 101 thread??Billy
1982 XJ1100, Ceramic Coated Headers, Raptor ACCT, Barnett Clutch Springs, Dremmel Fix, TC's Fuse Block, De-Linked S/S Brake Lines, 850 Final Drive, Yahman's YICS Eliminator, Pods, stock jetsComment
Suzuko still has the teeny o-rings and teeny washers for the recessed idle mix screws MackThere are two sizes for the metal on metal needles. One is 17.5 mm for later carbs and the other is 15.1 mm for the early carbs. I can't find any source that gives the measurement so I know I'm getting the right ones. Anyone have a source? Also I'm looking for the small rubber washers for the later idle mixture screws.
. BillyRok has the part number in post#3 that had psted long time ago.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Thanx guys
Replentishing my stock.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
For the metal on metal, there is just one size. The early carbs had this. The later carbs had a neoprene tip on the needle. You can usually get the whole seat and needle at Partsnmore for less than just the needles.
Vintage Honda, Yamaha, Kawasaki & Suzuki motorcycle parts. Find carburetor kits, brake parts and seals by model and year. Free USA & Canada shipping over $50.
Also, you might check Harbor Freight for the o-rings. They have a whole assortment of the Viton o-rings for just a few bucks and there might be the size you need in there. Not sure how small they get in that kit, but some are tiny.Try your hardest to be the kind of person your dog thinks you are.
