There are two sizes for the metal on metal needles. One is 17.5 mm for later carbs and the other is 15.1 mm for the early carbs. I can't find any source that gives the measurement so I know I'm getting the right ones. Anyone have a source? Also I'm looking for the small rubber washers for the later idle mixture screws.
float needles
float needles
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None
Niche Cycle Supply has a good assortment of Mikuni parts, but you need to know the Mikuni part number you're looking for.I think I have a loose screw behind the handlebars.
This was what worked on my XJ carbs...from a post I started a couple years ago -Motoman told me the o-rings are still available from Suzuki, part number is
13295-29900. He was right, I'm looking at 4 of them now. Maybe the part number should be included in the Carb Cleaning 101 thread??Billy
Originally posted by mack View PostThere are two sizes for the metal on metal needles. One is 17.5 mm for later carbs and the other is 15.1 mm for the early carbs. I can't find any source that gives the measurement so I know I'm getting the right ones. Anyone have a source? Also I'm looking for the small rubber washers for the later idle mixture screws.. BillyRok has the part number in post#3 that had psted long time ago.
Thanx guys
Replentishing my stock.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186
For the metal on metal, there is just one size. The early carbs had this. The later carbs had a neoprene tip on the needle. You can usually get the whole seat and needle at Partsnmore for less than just the needles.
http://www.partsnmore.com/parts/yama...itting]=custom
Also, you might check Harbor Freight for the o-rings. They have a whole assortment of the Viton o-rings for just a few bucks and there might be the size you need in there. Not sure how small they get in that kit, but some are tiny.Try your hardest to be the kind of person your dog thinks you are.
