Neutral light on in fifth gear
  • dbmb0416
    • Jun 2015
    • 128
    • Westdale Ny
    Every once in awhile the neutral light comes on and it flickers in fifth gear. Sound like a wiring problem or something In the gears? Rides great in fifth gear with no problem when light comes on. Thanks
    79 XS11SF
    The switch is under the engine, on the left side. You can see the wire come out of the bundle that goes to the pickup coils. My guess is the wire has worn through, and is grounding on the engine or frame, and lighting the little green light.
    • dbmb0416
      • Jun 2015
      • 128
      • Westdale Ny
      I will check thanks
      79 XS11SF
      • justinc1081
        • Apr 2013
        • 61
        • Springfield, MO
        well that is a coincidince, i was going to post this same issue!
        will checkout that wire, ride home today i got stuck in heavy rain for about a mile, lost 2 cylinders for the next 10 while everything dried out, after that ran like a champ again
        80 SG
          Shorting in the harness with the pick up coil wires. They and the neutral light wire are all in there together.
          Justinc1081, the plug behind the fuse panel for the pick up wires is probably getting water in it and shorting the connector. Pack that connector with dielectric grease and I bet the issue goes away.
