? about polishing forks
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    Mother's had a product years ago. It was a jar that contained a brillo'y material that you broke off and shined up with. Worked great! Can't find it. They have an aluminum polish that goes on with a rag now.
    Are the forks lowers alum?
    What do you guys use?
    Lowers are in good shape just looking weathered and want to shine up.
    Rob - 79 SF
    Yes they are.............and a short 3in. tall jar with a blue screw-on lid. Auto Zone or O'rielly's has it. Works extremely well, but forgot the name of it, sorry.
      • 3917
      Are you referring to Eagle One's "Never Dull"? Silver tub, with oiled batting?
      I have some here. Bought it at Auto Zone.
        Found it...........BlueMagic metal polish creme
        • mrhammer2u
          • Aug 2014
          • 472
          • Northern, NJ
          Nice!! That's what I'm looking for. It wasn't Mothers, it was this stuff. The wadding is what digs in and brings out the shine with much less elbow grease than most I've tried. Off to AZ!
          Rob - 79 SF
          • 79XS11F
            • Jul 2006
            • 3563
            • Ottawa, Ont. Canada
            English custom polish
            It's the best polishing product I have ever used. I did my restored bike with it and wouldn't even bother looking at other products now. This 3 part kit melted oxidation away like magic.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • dbeardslee
              • Nov 2007
              • 4385
              • Maineville, OH
              Unless I'm mistaken there's a coating on the forks, and the coating is what yellows.
                • 7785
                Not mistaken. They had clear coat on them. Should be yellew or gone by now.
                • dbeardslee
                  • Nov 2007
                  • 4385
                  • Maineville, OH
                  But if it's not gone, is polishing really going to do anything? Seems like you'd need to strip it off first, then polish.
                  • MPittma100
                    • Aug 2011
                    • 2359
                    Polishing
                    Probably not. I have removed remainder of deteriorated clear coat on forks with Acetone and/or Lacquer thinner. Then used Mother's polish. Works well. It is quite labor intensive.
                    1981 XS1100H Venturer
                    K&N Air Filter
                    ACCT
                    Custom Paint by Deitz
                    Geezer Rectifier/Regulator
                    Stebel Nautilus Horn
                    EBC Front Rotors
                    Limie Accent Moves On In 2015
                    Mike
                      • 7785
                      This will remove the clear coat in 2 seconds. I would disassemble the forks before using it as it will probably melt the fork seals.
                      I just discovered this stuff. If my students can get aluminum to shine with it, anybody can!
                      • mrhammer2u
                        • Aug 2014
                        • 472
                        • Northern, NJ
                        My forks are not yellow, just dull and blotchy. I can't tell if there is any coating left. I'm thinking after 35 years,..no? I've only had the bike 2 years so I don't know the history. Hopefully some polish will shine them right up.
                        Rob - 79 SF
                        • dbeardslee
                          • Nov 2007
                          • 4385
                          • Maineville, OH
                          That coating doesn't exactly wear off. It would be like the paint wearing off a car - even after thirty five years there would still be quite a bit of paint left. And cars rust, but sealed aluminum doesn't oxidize, which is why the coating is there. I took it off mine with abrasives but I think a chemical process would probably give you better results. You might try a little dab of stripper in an out of the way area and see what it does. Could save you a lot of elbow grease. JAT
                          • 79XS11F
                            • Jul 2006
                            • 3563
                            They do need to be striped first with a strong paint striper like the aircraft paint remover. then polish as necessary and re-coat with an appropriate clear coat or polishing will become part of maintenance.
                            Rob
                            1978 XS500E
                            1981 Suzuki GS1100
                            • jwhughes3
                              • 2798
                              • Home of the Alamo
                              Try coating it with Sharkhide after polishing to keep it from re-oxidizing.It ain't cheap but its Marine Grade - designed for exposure to saltwater.
                              John
                              '81 XS1100H - "Enterprise"
