jet needles
  • mack
    • 2411
    • Ontario, Canada
    jet needles
    If the jet needle for an SG (452-14116-16) is 5glz-18 what is the correct number stamped into the needle for a G (360-1416-07-00)?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 2096
    Hi Mack, I beleive it's 51Z7 off the top of my noggin but I'll check.
      80-81Specials BOTH had 5GL16 metering rods Mack
      • mack
        • 2411
        • Ontario, Canada
        pilot air
        Ok so did the pilot air jets chaNGE IN 80 OR 81 TO 185'S?
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • dbeardslee
          • 4385
          • Maineville, OH
          Service manual says 5IZ7 for a G model, and that's the number that should be stamped on it.
          • mack
            • 2411
            • Ontario, Canada
            Thanx
            good to know.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
              Neither..........still 42.5's
              • mack
                • 2411
                • Ontario, Canada
                I was
                questioning the pilot air jets not the pilots themselves Brant. I got a set of 1980 carbs in last week that had 132.5 mains and brass floats in them. Never seen that before either. No idea what the bike they came off was like but it did have the 5glz-18 jet needles with the clips set at the richest setting. Must have milage like a dump truck.
                Had my SF & LH out for a two day run on the weekend and the SF was getting 42 mpg and the LH about 44. I'm pretty happy with those numbers as we were riding fairly aggressively.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                • Prisoner6
                  • Aug 2013
                  • 1184
                  • Phoenix, AZ
                  Mack,
                  For U.S. models, the pilot air jets changed to the 185's for the 1980 model year.
                  Marco
                  1979 Honda CBX
                  2002 Kawasaki ZRX1200R
                  WE MISS YOU, DON
