Want to change for stainless cap heads looked under mods but no joy, has anyone got the sizes I would need for an sf mod, stainless washers maybe?
Header studs/cap head bolts?
79SF
xjr ohlins shocks, tarozzi forkbrace, bsa handlebars, bsm exhaustTags: None -
Howdy- That's one thing I'd recommend you not to do. Buy new studs, buy the nuts, and enjoy the look.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights. -
The po changed to bolts rather than studs, are stainless studds nuts an option?79SF
xjr ohlins shocks, tarozzi forkbrace, bsa handlebars, bsm exhaustComment
Those are a 10mm fine thread IIRC, and you won't find anything ready-made in stainless because SS galls so easily in a fine thread. You may be able to find a chrome nut; somewhere on here is a post where the owner found some that would work, but he had to make the washers. The ones he found were not duplicates of OEM, and there was no follow-up to know if they worked out.
If you know a machinist, it wouldn't be too hard to make some out of some stainless hexagonal bar stock. MAKE SURE YOU USE ANTI-SEIZE ON THE THREADS!Fast, Cheap, Reliable... Pick any two
Thanks, found on evil bay a full set stainless with nuts wash:-)ers and gaskets made as a direct replacement for 50 GBP
79SF
Item number 261327345495 thanks79SF
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I put stainless acorn nuts on mine. They got slathered with a generous amount of anti seize compound first. Since the block is aluminum and the studs are steel, there will always be some galvanic corrosion going on. Adding stainless may make it worse, so anti seize is not optional. You have to use it.Marty (in Mississippi)
XS650EComment
Thanks for the info, the stud kit comes with a tube of anti seize79SF
Question, does anti seize make it more likely that nuts will come undone through vibration?79SF
No. Just be advised that if you use a torque wrench, you'll be applying more torque than if the threads were clean and dry. Torque specs are given for clean dry threads unless otherwise specified.
I would use the antiseize. Check the exhaust bolts periodically.Marty (in Mississippi)
XS650EComment
Jardine Spaghetti with Harley MufflersComment
