Did the standard gas caps have a different rubber gasket from the specials? If so anyone have a source?
Gas cap seal
Gas cap seal
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
It's not the same. Unfortunately, that's all the help I can give you.Marty (in Mississippi)
XS650E -
Mack, not sure if these guys were successful but they suggested a part on mikesxs http://www.mikesxs.net/product/20-0036.html
here's the thread: http://www.xs11.com/forum/showthread...gas+cap+gasket
partzilla has an OEM part http://www.partzilla.com/parts/detai...641-00-00.htmlFrame: 79 XS1100S
Engine: 81 XS1100S
Carbs: 78-79 BS34
Gf bike: 78 XS650S
Carbs: 70-79 BS38
Pics: http://tinypic.com/2mpmkpjbComment
Mack, I have used the MikesXS gasket shown in the link above on my Standard. I can't remember if I had to modify it any, but it is on there and works fine.2H7 (79) owned since '89
07 Triumph Tiger 1050
☮Comment
I actually
had one from mikes in my spare parts bin. It doesn't fit quite right on the standard cap but the spring does it's job well and I think it will provide a better seal because,it is conical inside then flat around the rim while on the special it just sits flat around the top only.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
