Do I need to be model specific when ordering brake lines?
Brake lines
Tags: None
Yes...
I ordered the set for a 1980 XS1100LG from these guys...
Lots of colors...good fit...the rear line is just one, so you'll not need the steel-rubber arrangement.
One thing though, the front grommets are not included, so you can use your old ones (they are a bit large for the new lines) or someone here stated that the correct fit can be ordered from Mike's XS...
I used the old ones...there are a bit large for the new, smaller lines...
I hope this helps!
TenormanBikes that I have owned and enjoyed...
1964 Allstate 250
1970 Yamaha DT1
1959 Mobylette
1970 Yamaha JT1
1995 Suzuki 80
1978 Yamaha XS650
1980 Yamaha XS1100LG
2005 BMW R1150R -
I got a set from Techna Fit a couple weeks ago, and yes you need to be model specific. The upper front brake hose will be a different length for a standard vs a special. I ordered a set for my '79F, and it came with all the grommets installed on the lines. The front upper was a little too short for stock bars, but I e-mailed them about it, and they sent me a longer line at their expense. I also had to grind a little width off the front keepers to fit the new grommets, which were a little narrower than the stockers. If you have any questions about the lengths needed it never hurts to call them first.I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
I also ordered Techna-fits ( 79F). I had absolutely no problems with anything- they were plug-n-play.
79 F
1967 Suzuki X6 Hustler
1973 Suzuki TM 125
1979 XS1100 F
2005 Kaw. Vulcan VN800
1991 BMW K75Comment
