Swapped a '78E Mechanical Advance onto my '79F
    • 3932
    Well, I finally got done with everything. Started out installing the Kuryakyn grips. Ras was right, you have to follow the instructions and file-off the ridges on the throttle tube to install it. No glue on the throttle side.
    After that, I replaced front and rear brake light switches. The front one does not work properly, as when I press the button in, the brake light activates. So, not sure if the 650's work backwards of our's, and their's use a normally closed, where-as our's use a normally open circuit.
    Anywho, got the "E" advance, vacuum pot, and the timing wheel on. Took me an hour to get it started, as I think I had the reluctor 180 degrees out (thanks for the tip Scott). Sitting at the "F" mark on idle, and 35 degree with the vacuum line detached at #2 carb, @ 5200 rpm.
    Did not touch the sync or A/F settings. I want to fill it up, and monitor the mileage.
    If anyone is curious what my ignition timing was with the "F" wheel and modified advance, it was 20 degrees at idle, and 35 @ 5200 rpm, with the vacuum pod plugged at both readings.
    • 9980
    Sounds like the timing is a bit far advanced at idle but pretty much spot on at 5200. 36 is what the manual says.
    Mine reads a little high at idle too, even down to 500 rpm.
      • 3932
      Wait, what? Why would it be too far advanced @ idle? Are you confusing my words Greg? However, after riding it 10 miles, I may hear a slight pinging at low rpms. There is a slight stutter upon taking off. Higher rpm's it does just fine. We'll see if this advance effects my mileage.
        Cam overlap time is a bit different between the two yrs..
          • 9980
          Originally posted by motoman
          Cam overlap time is a bit different.
          Yamaha cam part numbers are exactly the same 78 and 79 Brant.
            • 9980
            I went to Harbor Freight today and bought a dial indicator so I can find TDC EXACTLY and get the timing marks dead on.
            http://www.harborfreight.com/media/c...mage_13704.jpg
              • 3932
              Here's what I did Greg: I used the depth gauge on my calipers and when it stopped raising, I figured that was TDC. My T mark seemed pretty close to that.
                • 9980
                I used a screwdriver and found the pointer to be about 5 degrees off. Got the dial indicator just to be sure.
                It was only $35.
                  Good response for me not looking up specs..
                    • 3932
                    Quick Question
                    When I sync the carbs, do I detach the vacuum pod vaccum line from the carbs and plug the #2 carb port? When I attached the Carbtune, not much vacuum was showing . . .
                    • red bandit
                      • 957
                      • central michigan
                      Leave the vacuum adv. hooked up. It's not activated at idle.
                      79 SF parts bike.
                        • 2122
                        It was only $35.
                        I use the same dial indicator, but I found there is enough backlash in the engine you have to keep rotating it in the 'running" direction.... noting the high reading on the dial over several cycles so you can try to land it exactly on the high point on a revolution.
                          • 9980
                          Turning the crankshaft there's no backlash.
                          I could have saved $35, I was dead on with the screwdriver method.
                            • 3932
                            I was tempted to go-out and buy that Greg, but I realized that depth gauge would be pretty dang close to a dial indicator (within a few thousandths).
                              • 3932
                              I'll have to raise the idle a tad. She wants to die at stop lights after 20 or more seconds.
