xj front fender on an xs?
  • phatts27
    • Aug 2012
    • 189
    • Clementon, New Jersey
    Hey guys,
    I've read that the xj1100 front fenders are reinforced. Would that fender swap onto my xs? I already have a tkat fork brace, would the reinforced-fender be overkill? The fender on my bike now is in great shape, but I have a shot at a nice xj part for cheap.
    Thanks,
    Ed
    81 xs1100 SH
    81 xs1100 SH (parts)
    80 suzuki gs550et
    07 suzuki S40
    Can't answer if it will direct fit, it probably could be re-drilled if necessary. The width should be the same.
      The XJ fender is a direct fit onto the Special forks, not so onto standard ones...
      Yes, it is reinforced somewhat better. It's also about twice as heavy as the one you have now. If you already have a fork brace, this will simply add unsprung weight with little gain.
      • phatts27
        • Aug 2012
        • 189
        Thank you Steve. Double the weight is insane! Smart thinking though on the engineer's part though for making the brace invisible when installed.
        81 xs1100 SH
        80 suzuki gs550et
        07 suzuki S40
          • 6765
          I still installed a TKAT fork brace on my XJ...the one built into the fender is of little use and the TKAT did improve things considerably...
          2005 Honda SilverWing 600
          2018 Honda PC-Xpress 150
