Help for bouncy front end at 80+ speeds
  • justinc1081
    • Apr 2013
    • 61
    • Springfield, MO
    0-79 the bike is great, anything over 80 and the front end feels like it's jumping all over the place. Removed air from the front forks and this helped a little but still quite bouncy feeling at speed. Anything to help this? Last time I did fork seals I put in heavier oil just hoping that isn't what is causing this. Also I thought I saw something about putting some stuff into the tire to help balance it, the rims have no weights on them.
    Thanks!
    80 SG
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Your front tire is not balanced. I had the same issue, until i put a new tire on.
    There are beads you can biy that go inside the tire to make it 'self balance'.
    I haven't tried them yet but others have.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    • MPittma100
      • Aug 2011
      • 2359
      Balance
      Remove the wheel. Take it to a place that mounts and balances motorcycle tires. Should not use over 15 weight fork oil. 10 is recommended.
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
        Justin,
        Before you take off the wheel, jack up the front end and spin the tire by hand.
        Look closely at the 'bead line' of the tire, it should be straight and level with the rim. If it seems to wander up and down or disappears down into the rim then the tire is not mounted correctly and it'll hop like crazy.
        • justinc1081
          • Apr 2013
          • 61
          • Springfield, MO
          tire spins free and bead looks solid, ill take it to get balanced soon. Wasnt sure if mag rims needed weights
          This bike is a freakin blast to ride now that its running
          Rode it like a hoonigan and got 34mpg out of the last tank
          Thanks all for your help!
          80 SG
            • 7781
            Slow down!
            • jwhughes3
              • 2798
              • Home of the Alamo
              Ha! Good advice Marty.
              I had a similar condition on my trip west in May. Front tire had just started to cup. Replaced it in Durango and voila! No more wavering at speed.
              John
              '81 XS1100H - "Enterprise"
              • justinc1081
                • Apr 2013
                • 61
                • Springfield, MO
                I try to do the speed limit, its the traffic around me that forces me to go that fast i swear officer
                80 SG
