Hi All,
I have been coming to the site from time to time to see what's new. Up to now not for any technical issues recently. I am back again asking for help for hopefully not too severe of a problem.
Getting ready for the season I addressed a number of issues that I hoped would give me a reliable short season here in Buffalo.
I put on new rubber (Shinko HD), S.S brake lines, New rectifier, solenoid, adjusted valves, timed, came chain adj, checked pick-up wires again, tightened/torqued throughout and of course changed oil. I probably had 5,500 miles last season with a few oil changes between for good measure. I had previously did the back cutting transmission fix the year before. It shifted flawlessly. Ran great and had good plug coloration. I felt terrific. All I wanted to do as well was a fork brace. Is the Tkat of your design, manufacturing and sales??
A few thousand miles in this season and I developed an issue and parked it wanting to avoid more damage. When it manifest itself I had to ride about 70 miles to make it home. When I got to my destination I put it on the side stand and it was making a crunching or grinding sound when leaned to the left side(shifter side)in neutral. Riding it home (obviously in gear
) sounded like something was dinging around in the oil pan. At slower speeds almost non-extent. When stood plumb on center stand in neutral it dissipates same with in gear on center stand (I think?)
Here's what I initially performed to try to identify the problem.
1. Removed oil pan to check for grindage and garbage. A miniscule amount fine powdery filings. I then took a pump sprayer and flushed with kerosene and blew out with air.
2. Checked compression which was within specs.
3. Removed clutch cover and basket. Visually checked all and put back together overlooking countershaft bolt at that unfortunately.
4. Removed starter when running
5. I removed shifter cover and inspected all components reinstalled.
6. Drained middle drive and inspected bearing under shifter side chrome cover which looked fine and poured in the proper amount of Stay-Lube gear lube and checked with the dipstick I made from here
I had previously installed a new u-joint at restoration, greased shaft and final drive to wheel drive with moly paste and changed final drive stay-lube to specs. The drive shaft spline looked impeccable. (Doing in neutral as well so not the issue I am sure) Praying after inspection. I crossed my finger and said a prayer. The Gods were not in my favor that day. It still did the exact thing.
I took it apart again today after a few weeks sitting (darn it all). To check the counter shaft bolt torque I researched and found answers in the form.
With a dowel it is hard to determine exactly where noise derives. It is more prominent at the middle gear but I would assume it wouldn't do in neutral? Also sounds perhaps on clutch side but everything looks fine visually (bearings, circlips countershaft bolt torque and the C.S. has no play side to side. As I said the transmission shifts and sounds like a fine watch without the new noise.
Am I perhaps looking at removing middle drive or is there anything you have come across in your knowledge base or experience? If I remove the 7 bolts from the middle drive will it just pull out or must the engine be out and what do I expect to see inside and how does it gear or attach to transmission?
I am looking forward to your reply. Hopefully it less severe than I anticipate and will require not a great deal of time or money to resolve so I can enjoy the rest of the season and eventually the fall leaves.
Thanks in advance,
Jeff outside of Buffalo NY
) sounded like something was dinging around in the oil pan. At slower speeds almost non-extent. When stood plumb on center stand in neutral it dissipates same with in gear on center stand (I think?)Here's what I initially performed to try to identify the problem.
Thanks in advance,
