need help mounting tire
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    I got the new tire on, but it won't fully seat on the bead.
    I've tried bouncing it MANY times with about 40psi in it.
    Is there a trick or technique that I'm unaware of?
    Any idead or help is appreciated.
    Thanks,
    George
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
  • jwhughes3
    • 2798
    • Home of the Alamo
    I would lower psi to about 10-15 and run a ratchet strap around the circumference.
    Squeezing the bead out.
    John
    '81 XS1100H - "Enterprise"
      • 8894
      You can break the bead loose again, apply a slippery substance to the bead, I use liquid laundry soap, when it dries it becomes super tacky. Then inflate as needed, up to 60-65 lbs to fully seat the bead. Don't forget to bleed the air down to desired pressure before riding. I also use a rag with mineral spirits to wipe the tire surface down just in case of the presence of a slippery mold release agent.
      • GLoweVA
        • Jun 2011
        • 1957
        Thanks John, i used the strap to get the tire to initially hold air. I got it up to about 20psi and released the strap and the bead mostly popped out. I then inflated to about 40 and tried bouncing it to get the last bit to fully expand.
        Thanks Phil, i did use a little soapy water when i was using the tire spoons/irons to get the tire on the rim.
        The problem i have have is i don't have a compressor. I have to use the pump at the gas station.
        Any other idea to try.
        The Green Monster
        Got him in '04.
        Scarlet
        Got her in '11
        Hugo
        Cold weather ride
        • alaskey2
          • Apr 2014
          • 271
          • 60940
          I'm using a bicycle pump I have to say I was excited when I got mine set.
          78 E
            • 8894
            Problem with that is it the soap dries up very quickly and the bead becomes stuck right where it is now. If you are still stuck, take it over to any auto tire shop and the fella over there will set you straight for a few $.
            • GLoweVA
              • Jun 2011
              • 1957
              I tried that Sat at firestone, but initially the tire wasn't seating enough to even seal so the air just leaked right by, so they couldn't help me. I went home and put the ratchet strap around it and use the gas station pump and got it inflated, but the bead didn't seat all the way.
              Cycle Gear wanted $47 to mount and balance it.
              So i did it myself. Now I'm on day 2, maybe i should have gone to them.
              The Green Monster
              Got him in '04.
              Scarlet
              Got her in '11
              Hugo
              Cold weather ride
              • clarkcortez
                • Aug 2004
                • 31
                • Nevada City, California
                Everyone has given excellent advice. Lubricate liberally with soapy water between rim and bead, Work quickly before lubricant dries. If stubborn you need to get a little bit animal with the bounce. I keep bouncing on both sides of the unseated area. Sometimes I have the tire/rim bouncing 2 to 3 feet off the ground, just hang on to it. If no success keep changing pressure. If it's the right size tire it will mount.
                "Little by little the look of the country changes because of the men we admire." Hud
                • BowlingSS
                  • Apr 2015
                  • 398
                  • Lawrenceville, GA.
                  I have used a rubber hammer on the area. I used soapy water first. Use a lot of it. I used a spray bottle.
                  You usually have to take the PSI up very high sometimes.
                  Good luck.
                  Bill
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    Success! 65Psi was the magic number.
                    A couple of bounces and bingo. Deflated back down to 30 and then the balancer.
                    Just need a little weight opposite the valve stem.
                    Thanks for the quick responses.
                    The Green Monster
                    Got him in '04.
                    Scarlet
                    Got her in '11
                    Hugo
                    Cold weather ride
                    • BowlingSS
                      • Apr 2015
                      • 398
                      Glad it worked out.
                      Bill
                        George, next time let most of the air out of the tire, then gently bounce/roll the tire on the floor or lay it on a couple of wooden blocks and work the sidewall with a rubber mallet to get the bead to lift up and seat.
                        If you're going to mount your own tires at home, don't use salt-laden soap, pick up a jug of stuff that's actually designed for lubricating rubber and mounting tires:-
                        NAPA: Lubricant - Tire Mounting / RuGlyde
                        Part Number: BK 7651338
                        Product Line: Balkamp
                        Attributes:
                        Container Size: 1 GAL
                        Chemical Container Type: Plastic Jug
                        Chemical Manufacturer: American Grease Stick Company
                        Chemical Primary Application: Premium Tire Mounting & Rubber Lubricant
                        Hazards or Warnings: Consult Material Safety Data Sheet / Product Label
                        Purchase Item
                        $14.49 /ea
                        Call Store for Availability
                        • ViperRon
                          • Feb 2011
                          • 1062
                          • Woodstock, VA
                          glad you posted that Scot about Ru-glyde I had asked people around here where to get it and they looked at me like I was crazy. I never thought of Napa. Parts stores did in the past sell it in 4 ounce bottles. Next time George use the ru-glyde its much better than soap.
                          Rodan
                          1980 G Silverbird
                          1198 Overbore kit
                          Grizzly 660 ACCT
                          Barnett Clutch Springs
                          R1 Clutch Fiber Plates
                          122.5 Main Jets
                          ACCT Mod
                          Mac 4-2 Flare Tips
                          Antivibe Bar ends
                          Rear trunk add-on
                            You're welcome, Ron, I didn't know what I was looking for at first but the stuff's great. I had a similar problem with blank looks at one of the local tire dealerships when I asked them where they bought their tire lube and they told me they just used dish soap. When I asked them how they kept the salt out of their customers' rims I got more blank looks and something mumbled about, "Salt? What salt? We don't use salt, we use dish soap!" so Mom's car isn't going back to that place.
                            My little brothers worked at NAPA so that ended that round of searching.
                              • 6764
                              Wow cant believe none of youse mentioned the fact that many times after removing an old tire the rim itself is dirty and can use a light sanding with a dremel disc sander that removes any debris that might prevent the new tire from making a good seal onto the rim...also makes getting the tire to set into the bead easier....Mark and I do this everytime a tire is changed...JAT
                              2005 Honda SilverWing 600
                              2018 Honda PC-Xpress 150
