On my 80 SG on the carb boots-what size is the line that goes on there? is it metric like 5 mm?
hose size
You talking about the vacuum line that runs to the octy? Rubber stretches, so it shouldn't make any difference is it's metric or sae. 3/16" vacuum line should work fine. If it's tight you can always spray a little WD in the end - makes it easier to slip over the fitting.I think I have a loose screw behind the handlebars.
The reason I'm asking-I have the Pingel vacuum fuel valve.Yesterday the hose that attaches to the bung on the manifold came off and bike shut off.I need to put a spring clip on so that wont happen.
I dont have the Octy anymore.This valve eliminated that.1980 XS1100 SG
Originally posted by oldyam80sg View PostThe reason I'm asking-I have the Pingel vacuum fuel valve.Yesterday the hose that attaches to the bung on the manifold came off and bike shut off.I need to put a spring clip on so that wont happen.
I will look at Advanced Auto for those clips.I have yellow Tygon vacuum lines so I can see everything!1980 XS1100 SG
Originally posted by oldyam80sg View PostI will look at Advanced Auto for those clips.I have yellow Tygon vacuum lines so I can see everything!I think I have a loose screw behind the handlebars.
Originally posted by oldyam80sg View PostMany thanks!I think I have a loose screw behind the handlebars.
