Hey Xarik,
No aspersions on your skills or knowledge set! We don't have any idea what folks know or don't until they tell us!
Okay, Db's provided lots of good advice. But I will advice that the size jets he's talking about are probably going to be TOO RICH! More on that in a little bit.
First off, here's a photo from this tech tip on how to put cheap pod filters on AND also make the bike easier to tune in general by the use of Velocity Stack style mounting.
This shows the Prominent Lip on the inside edge of the EMGO style filters...the actual filter element has been removed to visualize the LIP looking directly into the inlet bell of the carb....note how much of the vac. slide port is blocked....it prevents the vac. slide from being able to rise to allow more air in and so it causes an excessively rich condition which gets worse with the higher the rpm's you try to attain.....folks reported that they couldn't even get it above 5K with the restriction!
The tech tips explain about the reasoning of using the velocity stacks.
The 80 and 81's are supposed to have essentially the same carbs....provided you don't have the rare bastardized early 80 series that still have the sharing tunnel between the pilot and main jet towers....which feeds the pilot circuit thru the main jet similar to the older 78-79 carbs....but the 80-81's use smaller mains. The later 80-81 carbs do NOT have a sharing tunnel and the pilot jet feeds directly from the carb bowl and not via the main jet. With the bastardized 80 carbs with the sharing tunnel...the pilot jet tower is supposed to be capped off with rubber plugs so that it feeds only from the main jet tower....otherwise it can be too rich.
The 78-79 carbs used 137.5 mains because they also had to feed the pilots. The 80-81 carbs use ~110-120 mains because the pilots feed from the bowl directly. Despite what the manual said....Yamaha did away with the staggering sized jets fairly early on in production....the cooling/heat difference between the center and outer cylinders was negligible. My 81 Special came with 110's across all 4...Yamaha jetted them leaner due to increasing EPA demands. I put 4-1 pipes on it very early on when I got my bike back in my ignorant youth....thinking that 4-1 pipes would provide more HP! Wrong....they just changed when the HP power band kicks in....moving it up a bit more in the rpm range vs. lower for OEM pipes. The OEM pipes with crossover were tuned for the best ALLAROUND performance.... low/mid/high throttle...but more for low/mid. Anyways....I ran it with those 4-1's for 7 years with OEM Airbox WITHOUT rejetting, and never burned any holes in my pistons...and had great throttle response thru most of the rpm range....redline in 4th....never was able to try it in 5th!
My bike died due to tranny issues, parked for 10 years, rusted, etc., rebuilt it with WISECO little big bore 1179cc kit, etc., and installed Pod filters...then shortly installed the velocity stacks....and it behaves great. I went up to 117'5's on the mains and 45's on the pilots. My compression levels were jacked up a bit with the big bore to around 180 psi...and so I have been using Hi-Test vs. Regular. Everybody says that for the stock bike/engine regular is all is needed, granted the compression of ~10.# to one vs. 9.0 to 1 isn't high octane required...but I didn't want to take any chances with my new $$ pistons...concerned that I might not be able to hear the Pinging of preignition! My plugs look great and have great throttle response..so even though it's a bit more $$, it works for me.
