Yamabond 4
  • DeanR
    • Jan 2005
    • 1495
    • Finger Lakes NY
    Yamabond 4
    Can Yamabond 4 be used sparingly on rubber gaskets ? Valve cover gasket on the Honda ST1100.
    Is an old (opened) tube still useable if the tube is still pliable?
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    Hey Dean,
    Here's a description I found for it!
    Yamabond 4 Motorsports is a silicone based liquid gasket that fills gaps on a flange surface and prevents leaks. When cured, this product forms a rubber-like body that resists heat and seals joints subjected to high temperature. Gear and engine oil resistant, Yamabond 4 Motorsports sets in 60 minutes. Not for use on copper or copper-based alloys.
    So...I would think as long as the rubber gasket is cleaned of oil so that the Yamabond will adhere to it, and the valve cover, should be just fine!
    • DeanR
      • Jan 2005
      • 1495
      • Finger Lakes NY
      Yamabond, Hondabond, and Threebond 1104/1194 all seem to be the same stuff. Probably Permatex Ultra gray too?
      or,
      maybe use Permatex Ultra Black.
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
        Dean,
        How old is the Yamabond?
        If it's really old it might be the original flavor that used lead, Pb. It'd be a shame to waste that on a rubber gasket, you can't get it any more.
        • DeanR
          • Jan 2005
          • 1495
          • Finger Lakes NY
          Originally posted by 3Phase
          Dean,
          Maybe 6-8 years!
          I don't understand the lead/shame to waste comment Scott.
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
            Yummy! That looks like Colonel Yamaha's original recipe.
            The lead in the goop helped make a soft, flexible metallic seal for metal parts -- like aluminum engine case halves -- that can move slightly relative to each other under normal use and run at temperatures that used to destroy conventional sealers.
            Lead is bad for children and other living things so of course the lead had to be removed from engine case sealer because a child might chew on your engine; fording streams and running in the surf could contaminate a fish or poison one of the endangered species of engine-case-sealer-eating birds.
            Use the goop however you like but don't rub your eyes and don't bite your fingernails. If you want to be 100% safe you should not even think about opening that tube (send it to me! ) but when you're done with it, make sure you bring the empty lead roll to the local hazmat site for proper disposal instead of tossing it in the trash.
            • MPittma100
              • Aug 2011
              • 2359
              Yamabond
              The new Yamabond tube directions include the statement that it should be used within one year. 7 year old tube might need to be replaced. I would be more comfortable with a new tube.
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
              • mack
                • 2411
                • Ontario, Canada
                Since we are
                on the subject, I have a tube of permatex ultra blue that I normally use for the swingarm/final drive connection but I want to try it on the carb boot/intake connection. Good idea or bad?
                mack
                79 XS 1100 SF Special
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                https://youtu.be/wB5Jfbp6SUc
                https://youtu.be/RaI3WYHSuWA
                Frankford, Ont, Canada
                613-398-6186
                • TADracer
                  • 1417
                  • Kenner, Louisiana USA
                  I have a tube of Yamabond that is well over a year old (not sure how much though). I think it might be a selling ploy to keep stock moving because the stuff is still like when I opened the tube. Pliable and rich. So I would not hesitate to use it.
                  Mike Giroir
                  79 XS-1100 Special
                    Hi Dean,
                    I would use either the gasket OR the Yamabond but not both together.
                      Hey Mack,
                      This statement was in the PDF datasheet by Permatex:
                      Note: Not recommended for parts in contact with gasoline.
                      Granted, the intake boots are only exposed to gas VAPORS, and not necessarily liquid gasoline...UNLESS you have a carb float valve leak!
                      • mack
                        • 2411
                        • Ontario, Canada
                        Tc
                        Yes I was looking for an expiry date and saw the disclaimer on the blue, switched to "Ultra Grey". I was in the shop and sent that by my phone but it must be suspended in the ionishere someplace.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                        • BowlingSS
                          • Apr 2015
                          • 398
                          • Lawrenceville, GA.
                          I have used Yamabond 4 for 35 years on gaskets. Works great.
                          Bill
                          Jardine Spaghetti with Harley Mufflers
